Front Hub or Rack/Pinion problem?
Old Mar 16, 2010 | 04:34 PM
mk4r34's Avatar
mk4r34
Default Front Hub or Rack/Pinion problem?
So the front driver side doesn't feel solid on HWY etc.so I did 9-3o'clock shake and it has noticeable movement.Even with the wheel off holding the caliper and steering rod it still has movement.Now I replaced all my front bushings including R/P a few months ago.I noticed pulling out of my steep driveway making a right I hear a small clink.Car is a 93 Manual,110,xxx miles,lowered on Megans,18x8.5.Rims....any ideas?Thanks
Old Mar 16, 2010 | 05:27 PM
good2go's Avatar
good2go
I'd check out the hub.
and double check the subframe assy bolts.
Old Mar 16, 2010 | 05:59 PM
mk4r34's Avatar
mk4r34
Don't think it's the hub and it's not the sub frame bolts.
So I had my dad hold or put his fingers over the boot(over inner ball joint?)When I did the 9-3 o'clock he can feel the movement there.It's not the R/P cause that would cause both ends to move.Is there a part to replace that?Any ideas what it is exactly?.
Old Mar 16, 2010 | 06:28 PM
good2go's Avatar
good2go
So is it just a bad ball joint then? figured you'd probably checked those when you replaced CA bushings
Old Mar 16, 2010 | 06:36 PM
mk4r34's Avatar
mk4r34
Na,not the ball joint on the arms or tie rods.The joint that connects steering rod to steering rack.you can feel it in the steering boot,that's what's shifting
FiveSeven
Jul 11, 2016 01:59 PM
husker741
Aug 22, 2011 09:22 AM
lexusben
Apr 17, 2011 02:38 PM
mk4r34
Mar 22, 2010 09:36 PM
scfocus
Dec 6, 2009 11:13 PM
