1jz ct20
Old Feb 22, 2010 | 07:30 PM
speed6's Avatar
speed6
Default 1jz ct20
anyone heard of putting the bigger ct20s (jdm) on a 1j with the 1j manifold? they look identical except the output flange is 3bolts on the ct12, round port. 4 bolt on the ct20, they are oval port. the ct20 is obviously bigger and upgradable to a steel shaft and to gt2528 specs. that is the reasonsing, and if they bolt with minor mods, then it's a great upgrade for the 1j
Old Dec 19, 2011 | 03:28 PM
AlbertTRD's Avatar
AlbertTRD
Its fairly a straight forward process.
Use the 1jz manifolds (port them bigger to accept the larger ct20 housing)
Drill the hole in it bigger.
then you use a 3/8 adapter to adapt the y-pipe so it all fits.
You wouls have to use the 2jz pluming.
Only down side is you have to convert the rear ct20 so that its a true parallel setup.
I do this. You make a sleeve, press it in, and then drill into the scroll so the wastegate regulates the scroll.
then just build a custom down pipe.
I take the Ct20 turbos and upgrade them to steel/inconel shaft and put GT2860RS compressor wheels up front.
Ceramic Vs Steel:
Steel shaft in:
Comparision:
Custom Downpipe to delete the sequential crap:
jmanhas
Jan 9, 2013 11:58 AM
BigGreen
Oct 1, 2010 09:52 AM
JZCHAOS
SC400 / 300 Classifieds
Sep 23, 2008 06:40 PM
loonyrobert3
Apr 14, 2005 06:01 PM
2.5tsoarer
Jun 16, 2004 04:24 AM
