automatic to manual sc400 conversion
I have been searching and have not found any threads dealing with installing the clutch pedal assembly and master cylinder. if somebody could post some links to threads that deal with these it would be greatly appreciated.
Its not too bad if you know what you are doing and have the patience. There are already three dimples where the holes are supposed to be on the firewall. The hard part is just getting under there in a really awkward position to drill the holes. After that use a porter to make the main hole for the Master cylinder big enough. Its just some meticulous work. Oh btw, the holes are behind some foam insulation on the firewall which you will need to tear off some. Good luck!
There a couple threads showing the swap or at least talking about it but most of the time they focus on the tranny work. I remember seeing a thread the other day where a member was just now doing his swap and he planned on doing step by step pics with instructions. If all else fails just pm the guys who have already done the swap.
https://www.clublexus.com/forums/per...-my-sc400.html
This is one of the threads and it was on the page after yours. In fact there were two threads all about sc400 manual conversions on the next page.
thats exactly what i was looking for.
