fuel leak help
Old Jan 9, 2010 | 06:31 PM
1of120's Avatar
1of120
Default fuel leak help
Hi I was trying to change my fuel filter and the nut going to the filter is all stripped and won't tighten the line up anymore. I have gas coming out. Can someone help me asap. What can i do
Old Jan 9, 2010 | 07:26 PM
Papajorgio's Avatar
Papajorgio
i had the same trouble with my filter, i just went to the parts store and got some hose and hose clamps and cut the old filter out nut and all and replaced them with the hose/clamp setup, as far as the leaking fuel i didnt have to deal with a leak because mine started to torque the pipe before even cracking the nut open, but depending how big the leak is you may be able to take a bar of soap and kinda grate it or force it into where its leaking, i heard soap hardens and seals small leaks temporarily in fuel systems, but also dont drive the car like that (super unsafe)... GL hope you solve your issue painlessly
Old Jan 9, 2010 | 07:43 PM
1of120's Avatar
1of120
thanks the soap trick worked for now. I feel like s*** right now though... any pics of what your hose and hose clamp setup looks like...? Thank you so much
Old Jan 9, 2010 | 08:04 PM
Papajorgio's Avatar
Papajorgio
sorry dont have any on my hard drive, and its WAY to cold to take a pic right now, but if one turns up ill post it up
Old Jan 9, 2010 | 09:14 PM
dwebb99's Avatar
dwebb99
you MUST use flare nut wrenches and be super careful when working with gas lines and hydraulics lines. My advice is to only fix it the right way and that is with the proper section of fuel line (and perhaps a new fuel filter) that is needed either from a junk/parts Lexus or from the Lexus dealer. Watching a SC burn to the ground because of a make shift patch repair on a fuel line would be a very sad sight. Also houses have been known to burn down when said car is parked in the garage.....
Old Jan 9, 2010 | 09:57 PM
SH_JZZ30's Avatar
SH_JZZ30
Teflon tape that is made for fuel lines work great too. You can find it at home depot.
Before doing this, you should spray pb blaster and let it sit for a while. Flare nut wrenches are a must to prevent any rounding of the fittings.
Old Jan 10, 2010 | 03:30 PM
1of120's Avatar
1of120
I found this sc300 on craigslist that is parting out so i'm just going to buy the whole fuel line. Any idea how much it's worth? Has anyone ever replaced this line? Is it a hard job? Thanks
wth98sc
May 27, 2014 02:00 PM
hfsdude007
Feb 7, 2013 06:12 AM
JAndersson
18
Jun 18, 2012 12:46 PM
93trappin
Dec 2, 2010 12:10 PM
