Throttle sticking
Old May 15, 2002 | 07:52 AM
Zoso's Avatar
Zoso
Unhappy Throttle sticking
Anybody else ever had a sticky throttle? The pedal doesn't want to go down. I've WD-40'd it, but no help.
Anyon else get this?
Old May 15, 2002 | 11:53 AM
ChrisK's Avatar
ChrisK
Very possibly you have to clean the throttle body.
Old May 15, 2002 | 12:16 PM
awj's Avatar
awj
Bluegr*** Performance
Someone else was talking about making sure the throttle body is clean when changing spark plugs as this must be removed for that job. It is very possible that this is the problem.
Old May 15, 2002 | 01:09 PM
VSsc400's Avatar
VSsc400
Many if not ALL high mileage SC's (especially 400's with 90k and above) develop ALOT of carbon buildup on the inside of the throttle body which blocks air flow when the throttle is lightly pressed. The plenum moves just a tad but the air flow is still blocked from the carbon buildup. The solution is to remove the throttle body and remove this carbon buildup with a good quality carb/FI cleaner. The carbon buildup is between the throttle body and the intake so it is not possible to clean it through just the opening on the TB. It must be removed. Remove the rubber intake boot and the 4 bolts on the TB. The bottom of the TB has two coolant hoses used to heat it up in colder climates. Remove those. Now remove the crankcase hose from the bottom. That's it. Be careful as the hoses may be brittle and we recommend replacement at this time. The total time-1hr. Secondly check the TPS (throttle position sensor) for wear. This is common on earlier cars and if you do replace it make sure you get the updated superseded TPS.
saw it in the FAQ thats going around here somewhere.
Old May 15, 2002 | 11:56 PM
007lexus's Avatar
007lexus
what does the TPS exactly for? If the sensor is bad, will a check engine light trigger?
007
Old May 15, 2002 | 11:58 PM
007lexus's Avatar
007lexus
also whats good cleaner to clean inside t-body?
007
Old May 16, 2002 | 04:40 AM
VSsc400's Avatar
VSsc400
according to the direction it says to check it for wear. I agree with you that if it was worn the check engine light would come on. I'm sure any good name brand carb cleaner (motorcycle speed shop) should have a good one. Don' know the name.
Mrfouche
Feb 24, 2017 04:44 PM
lexus-is2
Dec 15, 2013 09:32 AM
matchesLS
May 26, 2012 03:32 PM
willfxp
Mar 7, 2011 12:59 AM
Rock-a-Lex
Performance
18
Jan 26, 2010 04:42 PM
