Factory Alignment Specs for 97 SC300?
Old Dec 31, 2009 | 08:35 AM
hksnlper's Avatar
hksnlper
Default Factory Alignment Specs for 97 SC300?
Does any one know the factory alignment specs for 97 SC300. Thanks in advance
Old Dec 31, 2009 | 05:12 PM
TheMole's Avatar
TheMole
Front
Rear
Old Dec 31, 2009 | 08:16 PM
hksnlper's Avatar
hksnlper
Thanks but I need one for 1997 SC300
Old Jan 1, 2010 | 01:21 PM
czar07's Avatar
czar07
its going to be the same as 1992,1993, 1994, etc
Old Jan 1, 2010 | 02:18 PM
5sp_jzz30's Avatar
5sp_jzz30
dude its the same car/chassis since 1992. just about everything is interchangeable including specifications on almost everything.
why do you think it would be any different if it one year or another if it is the same generation of car?
Old Jan 3, 2010 | 05:30 PM
ISFFUN's Avatar
ISFFUN
The alignment specifications are most likely different between the years because the tire sizes changed in 1995 and the control arm design changed in 1997 or 1999.
I do not have the numbers but I'd think they are different. You obviously can't assume they are the same, take the LS400 for example. The suspension was changed in 1993.
Old Jan 5, 2010 | 08:50 AM
hksnlper's Avatar
hksnlper
Thanks.....
Old Jan 16, 2010 | 09:17 AM
Luxor's Avatar
Luxor
Here are the specs for a 1998. I believe everything suspension-wise from 1997 to 2000 are the same. Everything that ISFFUN said is true.
Attached Thumbnails Factory Alignment Specs for 97 SC300?-1998alignmentsc300.jpg
Old Jan 16, 2010 | 10:57 AM
hksnlper's Avatar
hksnlper
Thanks a bunch you are a life Saver
kenDRIC
May 6, 2015 09:15 AM
ISFFUN
Oct 19, 2011 08:47 AM
StiCk3
Maintenance
Jun 27, 2008 05:35 AM
lexsc3
Wheels, Tires & Brakes Forum
Jun 29, 2006 09:30 AM
Dohc3l
Jun 5, 2004 09:50 AM
