rotor studs are broken off (help)
Old May 13, 2002 | 11:24 AM
jersey1's Avatar
jersey1
Default rotor studs are broken off (help)
I dont know what the what correct name is, but the 5 screw studs
that holds your rims on the car. One of them are broken off and i need to fix that before i put my 20" rims on, can you replace the screw itself or do you have to replace the whole plate.??????????? and how easy is it to do your self?????and about how much is it going to cost
Old May 13, 2002 | 01:18 PM
Ali SC4's Avatar
Ali SC4
you can have just one stud replaced. I think the studs cost a few dollars and istalation will run you like $40-50 since they have to remove the rotor, knock the old on off and screw in a new one. If you have a NTB nearby they do it pretty quick.
Old May 13, 2002 | 02:11 PM
jersey1's Avatar
jersey1
thanks bro! what about a tire shop and what is a NTB
Old May 13, 2002 | 02:24 PM
Ali SC4's Avatar
Ali SC4
NTB is national tire and battery, its the place that replaced the studs on my maxima when one got stripped. But most tire shops that also do repairs can do it.
OCLEX03
Wheels, Tires & Brakes Forum
Jul 15, 2010 10:59 PM
Hunterfl13
GX - 1st Gen (2003-2009)
Mar 24, 2010 03:06 PM
sc4001992
Sep 9, 2006 07:15 PM
zmatrix
14
Nov 11, 2003 04:11 PM
