Steering Slightly Loose
Old Dec 23, 2009 | 05:01 PM
CP_Ree's Avatar
CP_Ree
Default Steering Slightly Loose
Hey, I was wondering if anyone could point me in the right direction. The car is not being driven right now because it's stored, but I remember that there was a slight "skip"-if you wanna call it that, when turning the wheel sometimes. It's almost like the rack is loose or something is loose ONLY at a certain spot sometimes. Anyone have any ideas? Tie rod ends? Something else?
Old Jan 3, 2010 | 06:49 AM
kez's Avatar
kez
check your steering rack bushings.
Old Jan 3, 2010 | 08:19 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
It could be a couple things. Steering rack bushings,inner tie rod ends,outer tie rod ends,play in the input steering shaft going into the steering rack,wheel bearing. If you can get your car on a lift shake the wheel side to side and up and down to see if there is a tie rod issue or a wheel bearing issue.
Bon
Aug 13, 2021 07:51 PM
plosey93es
Apr 4, 2019 07:41 PM
Fliggy
Oct 15, 2015 07:14 AM
manalive20
Suspension and Brakes
Apr 10, 2007 10:09 AM
