intercooler pipng question
Old Dec 17, 2009 | 09:39 PM
soarer13oy's Avatar
soarer13oy
Default intercooler pipng question
Is this enough piping for a fmic??
PACKAGE INCLUDE:
2 x 11" straight aluminum pipe
2 x 13" 90 degrees aluminum pipe
4 x 15" 45 degrees aluminum pipe
6 x straight blue 3" coupler
2 x 90 degrees elbow blue coupler
16 x steel clamps
Old Dec 17, 2009 | 10:58 PM
Guest
Guest
Posts: n/a
i just ordered the same one but with the extra U pipe... i hope it's all i need
Old Dec 17, 2009 | 11:04 PM
turbodremz's Avatar
turbodremz
be sure to get those pipes welded or bead rolled..other than that it seems like it would be sufficient.
Old Dec 18, 2009 | 06:42 AM
SH_JZZ30's Avatar
SH_JZZ30
Yes that's more than enough. Make sure you get them bead rolled and buy tbolt clamps. And get silicone couplers. At least 4ply. Those are rubber couplers which suck. I had one pop a hole on me. So all you should use is the piping. You will have to make a hole behind your passenger side headlight.
Old Dec 18, 2009 | 07:15 AM
SC300_704's Avatar
SC300_704
i got pretty much the same thing except mines 2.5" pipings and my couplers looks stiffer than the ones in the pics. still waiting to be installed once i finish buying everything i need.
Old Dec 18, 2009 | 05:15 PM
soarer13oy's Avatar
soarer13oy
The hole behind the headlights, would i have to relocate my battery? Im also looking at this kit.
Straight Aluminum Pipe x2
45 Degree Aluminum Pipe x2
75 Degree Aluminum Pipe x2
90 Degree Aluminum Pipe x2
U Aluminum Pipe x1
Straight Silicon Hose x6
90 degree Hose x2
Stainless Steel T-Clamp x16
This kit has 9 pcs of Pipes, Compare to Most others offered, we have one Extra U pipe.
Great for Many Turbo Intercooler Applications
2mm Thickness, 18" Long/Each
The pipng will go on this hks intercooler:
Old Dec 18, 2009 | 05:31 PM
Guest
Guest
Posts: n/a
that's the one i ordered ^ 3 inch also i relocated my batt so i can cut a hole and run a pipe thought it
Old Dec 18, 2009 | 05:39 PM
soarer13oy's Avatar
soarer13oy
Is it possible to not run that hole? Cant i just run down from the gte tb?
Old Dec 18, 2009 | 09:25 PM
SH_JZZ30's Avatar
SH_JZZ30
Yes you can. That's how I have mine. I only have a hole behind the headlight for the hotpipe. Make sure your coldpipe sits high enough if you're low.
Old Dec 19, 2009 | 01:18 PM
TURBO819's Avatar
TURBO819
I did not want to make any cuts so I ran mine like this.
Attached Thumbnails intercooler pipng question-picture-246.jpg   intercooler pipng question-picture-273.jpg   intercooler pipng question-picture-257.jpg   intercooler pipng question-picture-256.jpg
Old Dec 19, 2009 | 01:29 PM
TURBO819's Avatar
TURBO819
Some more pictures of FMIC with 2.5" piping & 3" off the throttle body. I still need to bread roll three pipes
Attached Thumbnails intercooler pipng question-picture-255.jpg   intercooler pipng question-picture-258.jpg   intercooler pipng question-picture-275.jpg   intercooler pipng question-picture-267.jpg   intercooler pipng question-picture-288.jpg
Old Dec 19, 2009 | 10:32 PM
soarer13oy's Avatar
soarer13oy
thanks for your pics. thats exactly how i want to run my hot pipe.
elidari
Jun 20, 2017 08:10 AM
cvES300
Oct 11, 2012 10:12 PM
Curry
NELOC
Jul 6, 2007 12:25 PM
