spacers on sc
Old Dec 12, 2009 | 04:28 PM
Superjatt's Avatar
Superjatt
Default spacers on sc
does anyone have spacers on there sc.. can someone post pics please
Old Dec 12, 2009 | 04:35 PM
t70 supra's Avatar
t70 supra
search dude hit the space bar between the keys
Old Dec 12, 2009 | 04:55 PM
MIGS's Avatar
MIGS
i have 25mm spacers all around.
whatever spacers you decide to go with, make sure they are Hub Centric.
Old Dec 12, 2009 | 04:57 PM
turbodremz's Avatar
turbodremz
the links below will answer all your questions:
https://www.clublexus.com/forums/search.php
Old Dec 12, 2009 | 05:21 PM
Superjatt's Avatar
Superjatt
i tried searching but i dint find any pics
Old Dec 12, 2009 | 05:26 PM
ashtray's Avatar
ashtray
look at turbodremz provided threads..goodluck!
Old Dec 12, 2009 | 05:29 PM
Superjatt's Avatar
Superjatt
http://www.driftspeed.com/index.php?...products_id=32
how are these?
Old Dec 12, 2009 | 05:36 PM
6SOARER's Avatar
6SOARER
I have something similar to those, Ichiban V2 and they work great so far ..
Old Dec 12, 2009 | 08:01 PM
Superjatt's Avatar
Superjatt
i was thinking of putting the wide body on my sc. just the rear quarter panel. you think it will look good with 25mm or 35mm spacers?
Old Dec 12, 2009 | 08:05 PM
TheKevin's Avatar
TheKevin
CL Folding 25,000
if you're going wide body, do it right and get wide wheels. dont cheap out
Old Dec 12, 2009 | 08:43 PM
Superjatt's Avatar
Superjatt
i already have wide wheels i need just a teeee weeny bit more space. so spacers are the answer..
Old Dec 12, 2009 | 09:05 PM
24boosted's Avatar
24boosted
Project Kics.
Old Dec 12, 2009 | 09:06 PM
Superjatt's Avatar
Superjatt
YEEEEE BOOOIIIIII
THANKS MANG
how big are your spacers?
Old Dec 12, 2009 | 09:09 PM
24boosted's Avatar
24boosted
^ 25mm ftw.
Old Dec 12, 2009 | 09:14 PM
soulific's Avatar
soulific
I actually did some research on spacers a while back. For the sc...
- Its said you can go 3mm on stock studs, and its ok with out changing studs, it will also still be hubcentric still even though the spacer is not, since 3 mm isnt that thick.
- 5mm is ok on stock studs, some people say its not. The majority of people say its ok. With 5mm, the spacer need to be hubcentric since its thicker.
- 5mm or more you need extended studs
- If you get 10mm or more you can get spacers with studs attached, such as kics, h and r ichiba and so on. This is so you dont have to change out the stock studs.
Members... feel free to correct any of this info if im wrong.
To OP, Hope that helps. You can also do some searching yourself and quit being lazy. Stimulate your brain.
