just want to know if sc has the low fuel warning light. my 97 sc doesn't seem to have it, the fuel gauge needle is all the way down to the last mark and theres no warning light?
^^ All I know is the tank capacity should be 20.6 ( I think?) and if the light ever comes on, I tend to fill up around 18-18.5 gallons. So you have roughly 2 gallons left when the light comes on. (From my experience!!)
Yeah, the SC' gas light comes on once you're almost empty. On the GS it comes on with 1/8 tank left and you can drive between 25/50 miles past the "E" mark. I can be on E and not worry on my GS. On the other hand with my SC', I just don't know.
yes its yellow but you have to get really low. It goes on and off as well every so often to remind you
It goes on and off because the fuel sender is too low, if you park on a incline or decline that will change the height of the fuel sender/fuel sending unit and it'll cause that fluctuation.
Keep driving on it and eventually the light will stay on. I filled up after i drove about 40 miles on the light and i still had a gallon and a half left.
Y'all r lucky, I think my fuel pump, float or gauge is whack. My gauge is soooooo innacurate, I use the trip odo, I fill it up and know I have roughly 400-440 miles till the car shuts off on me! I at 300 miles I fill up. Except once I had a blow out (rear camber) and as I was pulling over I ran out of gas and had to push her fat *** off the shoulder of I-5. Hahaha...that day sucked.
