Need Help.Problems with Sc400
Old Nov 4, 2009 | 05:44 PM
abboushi's Avatar
abboushi
Default Need Help.Problems with Sc400
hey guys just bought a 1997 Sc400. i just got the brake pads and all four rotors replaced as well as new sparkplugs and a new battery. but i think theres another problem but i cant figure it out. first one is that the heater doesnt work. the ac blows very cold but when i put the temperature up to HOT it stays cold. and second problem is that after driving the car for say 20 minutes or so, when i get out it has a really bad smell like something was burning, i looked under the hood but didnt see any smoke however at night when the headlights are on and i get out i see a little smoke but after opening the hood theres nothing. i appreciate it if someone can help me with the situation. thanks in advance. oh and heres a pic of my car
Old Nov 4, 2009 | 07:04 PM
okbobbo's Avatar
okbobbo
Default Search
Search "heater problem". There is an extensive thread.
Old Nov 4, 2009 | 08:09 PM
maynanator's Avatar
maynanator
i had similar problem but when i turned the car made a whinig sound, i took it to a mechanic, all it needed was new fluids
Old Nov 5, 2009 | 12:16 PM
abboushi's Avatar
abboushi
alright thanks guys, ima go change the fluids because i have a feeling itll do something for me bc im getting that wining noise now too.
Old Nov 5, 2009 | 02:59 PM
kanderson's Avatar
kanderson
Make sure and check the radiator for leaks under pressure. If the coolant were low then the coolant level sensor should be on on instrument cluster.....
Old Nov 5, 2009 | 03:26 PM
SC400Dude's Avatar
SC400Dude
Welcome back from the dead dude...haven't heard from you in a minute! Nice SC...
Old Nov 5, 2009 | 03:45 PM
imarshall's Avatar
imarshall
Id say its the radiator fluid a bit low. I have this problem to and im going to get to it this weekend. Was the car sitting for a while before you bought it? That could be the reason. OR, when installing your brakes and rotors, your calipers (one or more) could have seized and it WILL give off a scent. To see smoke from the headlights, is normal. Its most likely just dust your seeing.
Old Dec 4, 2009 | 05:39 PM
abboushi's Avatar
abboushi
Thanks Guys flush worked..
iridebmx
May 16, 2010 10:34 AM
TWG1160
Mar 4, 2009 11:32 AM
Majend
May 15, 2007 05:38 PM
wf_sc4
Nov 8, 2005 02:43 AM
