turn signal problem.... need help!!!!!
Old Oct 20, 2009 | 12:43 PM
CrZxDrAgOn's Avatar
CrZxDrAgOn
Default turn signal problem.... need help!!!!!
so i have a 1992 sc300.. and when i use my blinkers.. it doesn't matter if its left or right.. and i make a turn.. the blinker doesn't automatically turn off..i have to manually stop it... is it suppose to be like that?? or something is wrong?? need some feed back guys!!!
Old Oct 20, 2009 | 01:09 PM
Lexscme's Avatar
Lexscme
nope its suspose to automatic turn off as the wheel turns back.
Old Oct 20, 2009 | 01:19 PM
CrZxDrAgOn's Avatar
CrZxDrAgOn
thx! now taht i know its not suppose to be like that.. n e one have n e suggestions.. on how to fix this???
Old Oct 20, 2009 | 01:23 PM
Lexscme's Avatar
Lexscme
i guess maybe you have to get a new column switch??
Old Oct 20, 2009 | 01:34 PM
soulific's Avatar
soulific
I think you have a bad clock spring. On my other car (volvo). I installed a quick release hub and aftermarket steering wheel. To install this I had to remove the clock spring. After this I had to turn the blinker off manaully. It doesnt shut off by itself anymore after a turn.
The clock spring basically acts as a trigger to turn off the blinker when the steering wheel is in a certain point.
I may be wrong though. This is just my experience with my volvo. I haven;t messed with the steering wheel in my sc yet.
Old Oct 20, 2009 | 05:47 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Thats my thoughts exactly, a bad clock spring. Remove the wheel and install the new one.. Make sure you turn it to the right 3 times, this assures its lined up properly. If not, the blinkers wont work or turn off automatically or the cruise light will flash 5 times, and not work either.
fernicus
Nov 23, 2024 09:58 PM
Cranford72
Sep 12, 2017 06:33 PM
buckwhite
Sep 29, 2016 06:25 AM
speedflex
Jun 9, 2010 01:14 PM
