Electrical Wiring Issues w/ Pics
Old Oct 20, 2009 | 10:04 AM
SC2JZ300's Avatar
SC2JZ300
Default Electrical Wiring Issues w/ Pics
I have a few plugs that aren't matching up. I need to know which wires will go to what....
The body plug -
The Engine Harness -
Also, this is the alternator harness... It has been extended into the cabin where the engine harness meets the ECU.... Which wires do these go to?
Old Oct 20, 2009 | 11:04 AM
ICONYQ's Avatar
ICONYQ
stock or hybrid harness?
Old Oct 20, 2009 | 12:09 PM
SC2JZ300's Avatar
SC2JZ300
The body harness is from the 92 shell(Underneath the fuse bux).
The actual engine harness is from a 95 1JZ Soarer Auto.
Old Oct 21, 2009 | 07:18 AM
SC2JZ300's Avatar
SC2JZ300
Anyone with info?
Old Nov 6, 2009 | 11:21 PM
SC2JZ300's Avatar
SC2JZ300
Anyone that can provide some help?
Old Nov 6, 2009 | 11:52 PM
SC2JZ300's Avatar
SC2JZ300
[U]Found some new info on wiring up the alt. This can be used for future reference, and for other people.
1JZ alternator:
White (S)
Yellow/Green (L)
Black/Red (IG)
1JZ Auto ECU Pinout
http://jzs13.se/wp-content/JZZ30_1JZ...ECU_PINOUT.pdf
Found the other answer to my question also.
The TT plug consists of 4 wires. The NA plug only consists of 3.
Pretty much str8 forward...
Red/Black - Red/Black
Black - Black
Any Blue - White
Other Blue - Nothing
Your TT harness may come with a 5th wire. It should be an extra smaller gauge wire(Black/Red). This wire should be soldered into the thicker gauge wire also black and red.
http://www.mkivsoopra.com/project/
Old Nov 7, 2009 | 09:54 PM
vangb2's Avatar
vangb2
Is this from a sc300 or 400? the second and thrid plug does not look familiar. The 3 wire plug is the EB2.
Black (EB2 pin 1)--To Starter. Engage wire.
White (EB2 pin 2)--To Alternator.
Black/Red (EB2 pin 3)--power to injectors, IACV, VSV, heat o2, and FP ecu. This wire is power from Main relay.
Post more pictures of the other 2 plugs, I can't identify it by the side.
Old Nov 7, 2009 | 09:59 PM
vangb2's Avatar
vangb2
Your alternator plug. Pull the heat resistance cover back so I can see the color of the wire where it is so I can tell what pin number they are.
Old Nov 8, 2009 | 11:40 AM
SC2JZ300's Avatar
SC2JZ300
I already figured it out. Thanks.
deputy865
SC400 / 300 Classifieds
Dec 21, 2016 09:13 AM
Golden95SC
Aug 24, 2014 12:22 PM
Matt300ZXT
Jul 31, 2014 07:50 AM
convoy
Nov 30, 2009 08:25 AM
