SC300 auto speed sensors (HELP!)
Old Oct 16, 2009 | 09:23 AM
ViP_SC300's Avatar
ViP_SC300
Exclamation SC300 auto speed sensors (HELP!)
1997 sc300 auto... Okay so the problem I was having was, a CEL light my speedometer and odometer on the cluster stopped working, rpm's work fine. So i picked up from toyota, a new TRANSMISSION SPEED SENSOR, changed it and CEL light turned off but, still same issue with the odometer and speedometer. While I was changing the sensor i noticed another sensor next to it. I did some research and found their is a transmission speed sensor and a vehicle speed sensor (wich should be the one next to the other one i just changed, both sensors are towards the extension housing of the tranny. does anyone have any experience/help/info they can share with me on this? im just trying to get my cluster and odometer to start working again. thanks.
This is the sensor i havent changed...(vehicle speed sensor?)
http://ecx.images-amazon.com/images/...6L._SL500_.jpg
This is the sensor i did change...(tranny speed sensor?)
http://www.******************.com/po...ZW5zb3I=&text=
Old Dec 27, 2009 | 02:54 PM
89MA70's Avatar
89MA70
I have the same problem with my cluster. speed and odometer doesnt work.
Old Dec 27, 2009 | 07:20 PM
ishootstuf's Avatar
ishootstuf
The 3 wire speed sensor is for the speedo, the 2 wire sensor feeds a pulse signal to the ECU for the electronic transmission.
I have a couple laying around...
Old Dec 27, 2009 | 09:57 PM
WetLexus's Avatar
WetLexus
Wow glad i came across this thread! This just happened to me today. Same exact problem...........guess im gonna be needing the speed sensor
Old Dec 28, 2009 | 10:22 AM
89MA70's Avatar
89MA70
Whats the difference between the 5spd and Auto speed sensors?
Old Dec 28, 2009 | 01:02 PM
CrazySC300's Avatar
CrazySC300
Yup! I just recently confirmed that I have a speed sensor malfunction as well...But SC's have 2 speed sensors...so I don't know which one is going bad...Anyone know what a "code 62" can tell me?
Old Dec 28, 2009 | 03:00 PM
ishootstuf's Avatar
ishootstuf
Old Dec 28, 2009 | 03:08 PM
ishootstuf's Avatar
ishootstuf
The W58 only has one speed sensor and I think it's identical to the auto 3 wire speed sensor. I think I used the one out of my auto when I did my 5 speed swap.
Old Dec 28, 2009 | 07:12 PM
dfwff618's Avatar
dfwff618
I have a '92 sc4 and my speedo is kaput. The odo, cruise ctrl and all other gauges work just fine. Is it the speed sensor or the the speedo itself?
Thanks a mil
Dustin
Old Dec 28, 2009 | 07:54 PM
CrazySC300's Avatar
CrazySC300
I just replaced my speed sensor and did a ton of city street driving and not once did that stupid O/D off warning light even blink once.
Old Dec 28, 2009 | 07:58 PM
CrazySC300's Avatar
CrazySC300
Malfunctioning speed sensors must be a common problem on SC's...I went to the dealership to get a replacement and lo and behold! They had the part in stock...And it was expensive as heck too!
Old Dec 29, 2009 | 06:38 AM
ishootstuf's Avatar
ishootstuf
Thanks a mil
Dustin
Sounds like the speedo itself, since there is only one speed sensor input to the instrument cluster.
Old Mar 22, 2012 | 11:02 AM
lex1220's Avatar
lex1220
I am having a similar issue. All of my gauges work except the speedo. It died. Cluster is out getting rebuilt as we speak hopefully its the fix! If not did your transmission speed sensor come with the gear or no?
Old Apr 5, 2012 | 01:45 AM
chargerfan's Avatar
chargerfan
on my speedo (5 spd) ... the rpm needle works, but the mph needle does not move ... so looks like my issue should not lie within the speed/gauge cluster right?
Old Apr 9, 2012 | 12:29 PM
herbSC3RSB's Avatar
herbSC3RSB
having a similar issue but my car wont get out of 1st gear does this sound like a speed sensor issue?
