Parasitic Draw Draining Battery
Old Sep 26, 2009 | 04:52 PM
sc250tt's Avatar
sc250tt
If your car is equipped with a telephone that can be the gremlin..I had the same problem with 2 of my sc's .This is also a probles whith many mercedes benz cars. If thats not the problem check for bad relays.
Old Sep 26, 2009 | 05:37 PM
ConSynX's Avatar
ConSynX
Batteries :-\
I went through THREE Optima Redtops in the span of its warranty (each with a defective section in time)...coulda added to the kill count, but I lost the receipt and was in a hurry. So I just got the $10 core for it and installed a plain lexus battery with something like 800cca.
Never again will I get the Redtop.
Old Sep 26, 2009 | 09:06 PM
tampa mike's Avatar
tampa mike
I am having the same issue, I just bought one of those 20 dollar battery cutoffs from summit, the kind that go on the positive or negative lead with the green **** and you just give it a twist and it disconects that lead. only thing i can do to help myself out from killin batteries like I am
Old Sep 27, 2009 | 08:30 AM
LEX_MAN's Avatar
LEX_MAN
anyone tried to unhook the ecu and check the voltage then? I'm doing that next, i'm tired of unhooking my battery everytime i go to work or home
i searched this site, and it helped one of the guys on here.
Old Sep 27, 2009 | 09:56 AM
ConSynX's Avatar
ConSynX
wonder if this is another one of those 1995 1jz problems
I figured it was Optima, but if I eat this new one quickly, i'll assume I have a very small drain somewhere. Probably at the radio since it likes to cut out on bumps (never looking to see if power goes or if cd skips)
Old Sep 27, 2009 | 05:43 PM
defrag010's Avatar
defrag010
Mine turned out to be the radio fuse. With the car off, the radio fuse was pulling like .2 amps!
Old Sep 27, 2009 | 08:19 PM
BigManne's Avatar
BigManne
whats the deal with 95 and 1jz's?
Old Sep 28, 2009 | 12:00 AM
markesc's Avatar
markesc
Batteries :-\
I'm SOOOOOO with you!!! FK those AHOLES!! Sorry I can curse I've been on the forums FIVE years, this is my first!
I too bought an optima after the Leswab battery went dead in my car (had to been over 4 years old)...so then...ugh...
I spent about a year dealing with the Redtop. I only drove the vehicle a few times a year, parasitic drain or not, I was pretty pissed to find that those batteries are garbage. No, not garbage, how about: complete overrated trash.
So I have two theories: 1) Those batteries just are not purchased enough so you end up with a pretty old battery @ Point of Sale. Unless you baby it, you're screwed. 2) They just suck unless you DD the car.
These cars are old. For most; they're hopefully 2nd vehicles?
So after a year of frustration, embarrassment (great when your car won't start on a f'n date!!!), and anger, I went to Les Schwab and purchased a new battery.
ZERO problems!! I can let the car sit for three months, everything connected.... hmmm I think I wanna drive my Lex... BAM! Starts up just fine!
Optima = Sorry, easily the worst product I've purchased in my 31 years of living....
Old Sep 28, 2009 | 04:56 PM
defrag010's Avatar
defrag010
Maybe you guys got a bad batch of optima red tops or something, because optima reds have been the best batteries I've ever owned. I put one in my '96 dodge in '99 and won my local usaci outlaw SPL competitions every year for about 3 years (on the stock alternator too, 154db)... and in 2005 that battery finally died. I bought a new one the same year and had it in my truck until I stopped driving it, then I pulled it and put it in my '74 dart for a few years until January '09 when I got my lexus and threw it in that. It still has plenty of juice and my car fires right up instantly every morning with no signs of drain. I expect it to last at the very least another year, which would make it 5 yrs old. 2 daily driven red tops in a decade isn't bad! Of course.. I always upgrade the ground and power wires under the hood of every car I own and test for parasitic drain to eliminate any long term drain.
Old Sep 30, 2009 | 08:39 PM
Lexus082's Avatar
Lexus082
I purchased and installed a new lexus battery today and everything is back to normal.
Old Jan 24, 2010 | 03:09 PM
usna2011's Avatar
usna2011
[QUOTE=defrag010;4879112]Mine turned out to be the radio fuse. With the car off, the radio fuse was pulling like .2 amps![/QUOTE
I just installed a radio in my car and i believe its the reason the battery keeps draining . How would i go about mesuring if the radio is drawing any current when the key is out of the ignition? I went to best buy and had a tech look at the wiring and he said it was perfect. There was nothing wrong with the wireing that would cause the battery to drain?
Old Oct 13, 2010 | 10:36 AM
twizted's Avatar
twizted
I also had 2 optima red tops and a blue top die in various cars but the batteries were tested bad and a old fashioned lead acid did last....
Old Oct 13, 2010 | 01:34 PM
lfrers's Avatar
lfrers
Yup, mine is on the trickle charger once a week and its a new Toyota batt. I guess the amps & dual electric air air pumps don't help. Alternator checks out.Its dead after a week of sitting. Too lazy to track the source. But since this thread popped up I got some troubleshooting ideas off some of the comments.
Umm... someone mentioned just disconnecting the batt every time? BAD Idea. Do it only if you don't care that your car will run like crap from constantly resetting the ECU.
Old Oct 13, 2010 | 02:20 PM
twizted's Avatar
twizted
Well you need to just put you multimeter so it can test current draw. Test at each fuse and when you find some usually more then 50ma or so track down everything on that circuit. Its just time consuming, you can get a thing called a fuse buddy and it will allow you to test each circuit without pulling the fuse. Mine is real weird and intermediate, my whole system can go down to only drawing 30ma at night and be dead some times 2 days after and some times not. Its some thing turning on draining then turning off so you have to catch it when it does it. Pain in the butt, could be a ecu, relay, who knows.
Old Oct 22, 2012 | 10:26 AM
rgaetano's Avatar
rgaetano
Curious, were you able to resolve?
