Headlight and Taillight Installs
Old Aug 27, 2009 | 04:23 PM
megamarine's Avatar
megamarine
Default Headlight and Taillight Installs
Alright, I've searched everywhere, and I mean everywhere. I need to find out how I can remove both my headlights and taillights from my 2000 SC300 so I can put new ones in. The front ones are becoming an irritant with e fogging up problem and the tail lights needed a change. So, can I get any help here? Because I don't want to start removing pieces I don't need to. Plus it'd help getting info from others so I could remember what to do.
Anyways, help a guy out?
-Matt
Old Aug 27, 2009 | 04:31 PM
masagsxr's Avatar
masagsxr
Its real easy.. U just need to look from the other side and remove the bolts holding them in place.
Hil's Avatar
Hil
Didn't search hard enough man.. there's a billion threads on this.
For the tails: remove the plastic trim where the trunk latch is, the whole piece should pop off. Then pull the carpet forward and you will expose the screws holding the tails. Loosen those, pop the tails out and unscrew the wiring harness for each bulb.
For the headlights: there are bolts on the top, and there are some inside under the fender. You need to jack the car up, or if your hands are small, just turn the wheel. Remove the splashguard and there are two 10mm nuts that need to be taken off from each side. If you want to remove the high beams you gotta remove the bumper
Old Aug 27, 2009 | 04:34 PM
megamarine's Avatar
megamarine
Failure on my part. My bad.
Anyways, thanks for the help man. Looks like I'll need to remove the bumper as the high beams are getting replaced too. Any advice on that?
Old Aug 27, 2009 | 05:39 PM
bangdangvn's Avatar
bangdangvn
here man http://www.lextreme.com/scbumper.html
Old Aug 27, 2009 | 05:46 PM
megamarine's Avatar
megamarine
Originally Posted by bangdangvn
You, my friend. Are made of pure, unsatured, 100% awesome.
Old Aug 27, 2009 | 06:04 PM
Hil's Avatar
Hil
Good luck with the bumper.. There's only like a million bolts
Tonyucf20
20
Jan 7, 2017 10:45 PM
xcskier
Dec 17, 2014 05:23 AM
dajwilson
Jul 13, 2011 06:50 PM
hybridanim
Nov 5, 2009 10:26 AM
Tony95sc4
Dec 3, 2006 02:03 PM
