It's in the same location as the Older SCs,There is and updated version which is the one i have. So if you buy one from a 97 you will get the last version !!!
When u look under the dash board u should see the mark if u remove the foam piece.
It's a little foam piece that u have to remove and behind it is where u suppose to drill
