How to: ABS / TRAC delete!
I just want to say that the roads were icy last weekend and had it not been for Trac...I may have lost my SC. I passed at least 8 vehicles who crashed before turning around and heading home from a trip to Jersey with my girl. Saw two oncoming cars hit the middle divider back to back, another two hit snow banks on the off ramp with me...it was bad. My car slipped at least 7 times and each time Trac helped me out. Not saying I needed it, but where other people crashed I stayed on the road. I know some of you guys don't get snow/ice, but for those that do it might be wise to keep Trac intact.
If you learn how to control your car on snow, ice, and rain-covered roads, you do not need, nor will you be helped by, ABS or TRAC. You're handicapped with RWD, but you can learn to compensate for it by driving carefully. In the winter, slap some skinny tires on your car, like 15x6.5, and get a better feel for the throttle on bad roads. Drive slower. Be careful. TRAC is garbage, and so is that ancient ABS system that left me rolling past stop signs and traffic lights countless times because the brakes apply so poorly with it. No matter what you choose to do, the SC is a piece of crap in the snow and ice.
Or, the ultimate solution is to junk the geriatric, slowly dying SC and get yourself a FWD or AWD car. I blow by endless crashed SUVs and trucks on the expressway every time we get bad snow up here in my FWD Ford Fiesta. FWD + modern traction control for the win.
I don't drive my SC300 in the winter anymore.
350 whp is no good for slippery surfaces, unless you have a modern sports car with a REAL traction control system.
Just wanted to verify that he deleted those parts. Would still love to see a step by step DIY with the easiest way to reroute the brake lines. There are 2 diff methods shown, I like to see the best/ easiest.
is there a cleaner DIY write up on this? my ABS and TRAC don't work anyways and i'd like to just get rid of them. so i need to get a T fitting from a corolla and some hard line and new SS lines??
thanks man.. and also you dont need a brake bias.. the master has one built in.. the line in the front is for the back and the line in the back is for the front... you can add a brake bias if you really want but i havent had one and no issues here.. stops harddd. also did supra tt rears with the ls400 fronts
Just my 0.02:
The Traction system in our cars is far from useless. Being one of the most advanced systems at the time, its not even considered old technology.
Yes its sensitive, especially on Ice, from a stop trying to take off.. but then again if you think about the following... Is it the car's fault?
Did you have proper OEM sized tires on the car, 225/55R16. Are they winter tires. Were you starting off IN Second gear (for autos that means selecting 2 and PWR on).
Were you trying to drag the car beside you.
Yes there are some cases where I understand/see Turning the TRAC off to take off is agreeable on extremely slippery surfaces. but It does do its job. It will save you and your car in the event you lose control especially when the car is going or about to go sideways.
I have nothing but praise for the system.
If you don't want it? push the TRAC OFF button.
If you want to remove the system because of weight? - lose some weight yourself, or remove your subs, or the spare tire.. but really its not that much of a gain, if you can call it that.
I can see why removing the system is agreeable when doing an engine swap. but that's about it.
again that's my 0.02
I don't know if the systems are different for the sc300 here - but the difference from having TRAC on my soarer, and not. is the fact I don't have the conventional Brake Booster - but a Pressurized Nitrogen Gas Accumulator and motor. Removing that and putting in a regular brake booster is silly and not cost effective. also the additional sensor on the throttle body isn't doing harm sitting there, used or not.
