A/c gets cold slowly
Is it just me or all SC does this? Whenever i use the a/c, i put on max cold and it blows hot/warm air for about 10-15mins then it starts to gets little cooler. then 30mins later it gets cold. Is this normal? becuase my daily driver (civic) gets cold in an instant.
My A/C will blow 50-60 degrees at the center vents idling in 105degree weather, and it takes about 30 seconds to do that.
You should take it to a pro for A/C related stuff....it's just easier for the most part.
One thing you may try is turn your key on, but don't start the car, and press the recirculation and auto temp control **** down at the same time to enter diag mode.
See if it has any stored codes, and let me know.
If you have something besides R-12 or R-134a in there, then it's normal.
Search for more info.
I thinking this is normal, When it hot inside the car it gets cold very slowly like at least 10-15mins. When it warm temp inside the car, it gets cold fast. BTW my car is 98 SC300.
foreste1
GX - 1st Gen (2003-2009)
May 6, 2017 08:57 AM
Ktreece777
Jan 17, 2013 04:31 PM
kevincao01
Oct 15, 2007 02:24 PM
