weight savings
Old Jul 31, 2009 | 04:16 PM
over40driv's Avatar
over40driv
Default weight savings
Just a note for all you weight lightening freaks like me,the cruise control is not light weight.
Old Jul 31, 2009 | 04:27 PM
megamarine's Avatar
megamarine
Hahaha, I bet. I always run with it off. Then again, I drift the big guy.
Old Jul 31, 2009 | 04:38 PM
CLNSC3's Avatar
CLNSC3
After I put an aftermarket steering wheel on my car I removed all the cruise control hardware as well. Besides the weigh savings it really helps to clean up the engine bay!
Old Jul 31, 2009 | 07:49 PM
AD_SC3's Avatar
AD_SC3
I ditched the steel spare and started running 1.5miles every day . Running = the best weight reduction.
Old Aug 2, 2009 | 10:16 AM
over40driv's Avatar
over40driv
Talk about cleaning up the engine bay, all that crazy ABS pumps and all is crazy.
Old Aug 2, 2009 | 10:52 AM
over40driv's Avatar
over40driv
Im wanting to lose as much of the TRAC. control as possible if any one has expearince on parts removal and how it affects the braking system, I would like to know how many parts can be removed.
Old Aug 2, 2009 | 09:27 PM
1siksc's Avatar
1siksc
lol, my weight reduction went all the way down to stripping the wires...
Old Aug 4, 2009 | 05:19 PM
over40driv's Avatar
over40driv
Installed my 2 dist. caps and rotors and the car runs better except when it wants to act up then it bogs.
Old Aug 4, 2009 | 06:05 PM
AyDee's Avatar
AyDee
I am running my car with no gas to reduce its weight - also no oil
My mechanic advised me to remove the transmission and keep on driving it downhills
Old Aug 4, 2009 | 06:07 PM
over40driv's Avatar
over40driv
If I could find a hardtop SC400 thatd be sweet.
Old Aug 4, 2009 | 10:49 PM
AyDee's Avatar
AyDee
I know a guy in St Louis who custom made one - It does not have a hard top or anything, its just topless - no seriously, it is convertible
It mainly a summer car - Should be garaged all the time
Old Aug 7, 2009 | 07:12 PM
KC95SC400's Avatar
KC95SC400
I will be removing my abs and trac system next weekend, keep an eye out for a "how to" thread.
If all goes well, should take an hour or two and about $90 dollars worth of off the shelf parts.
KC
Old Aug 7, 2009 | 07:38 PM
1siksc's Avatar
1siksc
^already have done and spent 86 dollars and about an hour of custom lines and so ss lines.
Old Aug 8, 2009 | 03:25 AM
KC95SC400's Avatar
KC95SC400
I have found that a couple people have done it but haven't found any sort of good write up on it. Found one write up on Supraforums.
I don't plan on chopping any of the hard lines. I'm just going to remove everything and use a couple of t's, adapters and ss lines to connect everything up. This way, it will be easy to put back if I ever need to.
Did you notice any difference (for the better) in pedal feel?
KC
Old Aug 8, 2009 | 07:24 PM
over40driv's Avatar
over40driv
I think removing the TRAC alone would be a good start, the small pump and accumulator under the master cyl.
