car problem
Old Jul 22, 2009 | 12:23 AM
grindin8o8's Avatar
grindin8o8
okay weird. today i started up my car. and let it idle for about 5 minutes. nothing was wrong with the car except on deceleration at like 3000 there would be a rattling/buzzing(sound like something loose) sound from under the car. maybe the exhaust is loose? leaked?
Old Jul 24, 2009 | 03:01 AM
topdog849's Avatar
topdog849
Probable Cause:
-spark plugs,wires,hose,oils,etc.
-exhaust leak
-iacv
-MAF and throttle body
-Catalytic Converter
-Intake Leak
-Fuel Pump
-Fuel Injections
-ECU
-??? any more suggestions of what can be the cause
you say that the problem goes away when the car is warmed up. well before the car is warmed up it runs in open loop and uses the ECT engine coolant temperature sensor to know how much fuel you need. and once the car is warmed up it runs on closed loop and relys on the oxygen sensors and MAF for fuel. you can rule out IACV as that only effects idle, if you had a cloggged cat you would notice great decrease in power. you can see if its the fuel pump ecu by bypassing it with a paper clip to B+ and Fp in the diagnostic port under the hood. replace your ECT sensor and report back
Old Jul 24, 2009 | 03:31 AM
grindin8o8's Avatar
grindin8o8
Originally Posted by topdog849
Probable Cause:
-exhaust leak
-iacv
-Intake Leak
-Fuel Pump
-Fuel Injections
-ECU
no the CEL goes away when it's warmed up. and the stalling/idling problem goes away when in motion.
weird today the car seemed to run fine. the only problem i have now is on deceleration i hear a rattling,sputtering sound, and sounds like it's coming from the driver side under the car. maybe a exhaust leak or cracked/loose bracket? because i also have a very strong fuel/stink smell when the car is running. what could be the cause of this?
if my problems reoccur again tomarrow i'll do the above you suggested. thanks
Old Jul 24, 2009 | 10:28 AM
topdog849's Avatar
topdog849
I strongly believe it's your maf sensor then. I have all of the same symptoms as you and I recently destroyed mine on accident trying to clean it with a maf sensor spray I bought at advanceauto
robert2423
Feb 13, 2017 05:45 PM
Salcedo90
GS - 1st Gen (1993-1997)
Apr 15, 2013 02:39 PM
vietstuh
Jan 29, 2011 04:03 PM
grindin8o8
Feb 4, 2010 05:06 AM
sliva001
Jul 3, 2007 05:35 PM
