SC Optics...
Old Apr 4, 2002 | 02:49 AM
lex400sc's Avatar
lex400sc
Default SC Optics...
Hey Manaray if you're still working on the OEM HID project, I did some work of my own. I removed the optics from my headlight assebly and took measurements of every dimension. Here's what they look like if you guys are curious...
First the stand alone optics assembled, but removed from the housing...
Old Apr 4, 2002 | 02:50 AM
lex400sc's Avatar
lex400sc
Here's all the loose pieces to the headlight as soon as you take it apart. There are some more not pictured, but I didn't want to remove them from the backing piece.
Old Apr 4, 2002 | 02:53 AM
lex400sc's Avatar
lex400sc
And here's the projector housing stripped of the lense, gromit, o-ring, and rubber seals. You're seeing the reflector, which focuses the bulb's light difussion, and the reflector shield, which produces proper cut-off line.
Old Apr 4, 2002 | 02:55 AM
lex400sc's Avatar
lex400sc
Another view...
Old Apr 4, 2002 | 02:56 AM
lex400sc's Avatar
lex400sc
Socket end with the 9006 adaptor ring removed.
Old Apr 4, 2002 | 02:57 AM
lex400sc's Avatar
lex400sc
Focal lens...
Old Apr 4, 2002 | 02:58 AM
lex400sc's Avatar
lex400sc
Profile of lens. It is pretty damn thick!
Old Apr 4, 2002 | 03:13 AM
lex400sc's Avatar
lex400sc
Headlight assembly minus the backing.
The low beam cut out is about 84mm in diameter.
The projector lens is about 78mm in diameter.
The projector assembly is 45mm on the outer rim of the socket end.
The projector assembly is 83mm on the outer rim of the mouth end.
The whole optic structure is 181mm from end to end minus the cruvature of the lens.
These measurements are as accurate as I could measure. My only measuring tool on hand was a tape measure in 1/32nd-inch increments. I did converstions and rounded numbers off. Margin of error should be no more than +/-1mm. When I find my metric ruler, I'll measure again and post results.
Old Apr 4, 2002 | 05:13 AM
Keith13b's Avatar
Keith13b
Ecxellent info !!!! Thanks.
This definately needs to go into a Tech article section - Hint Hint mods!!
Old Apr 4, 2002 | 07:17 AM
SC300TURBO's Avatar
SC300TURBO
good info and pics...but what are you tring to accomplish?....or the problem your trying to solve?......i have a headlight apart in my garage waiting for cleaning....are you doing somehting to make HIDs look better?...im interested..Jeff
Old Apr 4, 2002 | 09:36 AM
Lex Luthor's Avatar
Lex Luthor
Jeff, i'm pretty sure he's attempting to retrofit an OE HID assembly with optics, I would assume for the leveling system and total 'factory HID' look you get when you have optics that were originally designed for HID. Am I right, lex400sc?
- JonJonIchiban
Old Apr 4, 2002 | 10:21 AM
lexcoupe's Avatar
lexcoupe
hey great post, be sure to keep us posted with what your doing with the HID's, I am also working on getting the facotry HID's to work on my SC. Thanks for the info though!
Kevin
Old Apr 4, 2002 | 11:20 AM
lex400sc's Avatar
lex400sc
Lex is correct. I am trying to get maximum dimensions for what will fit into our headlights so I can begin shopping for an HID replacement. The process will slow somewhat from here on because my feet are bound as far as driving around and finding donor HID optics. I will continue to browse for dimensions online though.
Old Apr 4, 2002 | 11:36 AM
lexcoupe's Avatar
lexcoupe
hey lex400sc you can try to get the Audi a4 lights or any audi, im sure that they have similar optics. I have seen those on the road and love the lights, just a thought.
Kevin
ps if you do get a hold of those tell me cause i would love to replace my optic lense with one of those bad boys. i love the way they project.
Old Apr 4, 2002 | 11:39 AM
lexcoupe's Avatar
lexcoupe
Default s4 headlight
here a pic of the S4 headlight im sure that the a4's also have the same check it out on www.audi.com
