View Poll Results: What's Under Your Hood???
Voters: 221. You may not vote on this poll
I'm in the middle of my swap. The engine bay is painted anthracite, it will be completely clean as in the picture. It was my first time painting and polishing but it has come out nicely. The spark plug cover will be painted black shortly.
I've deleted the ABS and cruise control. The battery and fuse box are relocated out of the engine bay.
My engine consist of a 2JZ-GTE with precision 76MM turbo, 272 cams/valve springs, 4" downpipe, 1000cc injectors/E85 setup, painted accessories with billet pulleys, and other polished parts. I replaced the water pump, oil pump, crank pulley, valve seals, FMS, RMS, and other misc seals.
The engine will be mated to a V161 with 6spd JDM diff and 6spd driveshaft. I should be dropping it in shortly.
I'm shooting for 800+ RWHP.
NA-T 20.22%
1jzgte 29.21%
1.5jzgte 4.49%
2jzgte 31.46%
1uzfe 14.61%
Only 89 Votes I know we got alot more engines than that??? LOL
Keep them coming.
1jzgte 29.21%
1.5jzgte 4.49%
2jzgte 31.46%
1uzfe 14.61%
Keep them coming.
JDM Mark IV Supra 2JZ-GTE/V160 -Garrett GTX4202R Billet/Carillo H beam rods/ CP pistons/Full race T4 manifold/Hypertune intake w/102mm throttle body/Full Ferrea head w/+1 valves//Titan 272 High Lift cams/ID2000cc injectors/triple Bosch 044's/RPS Triple C/C clutch/Greddy 4 row/Fluidyne radiator/ProEFI ECU w/flex Fuel - 1012 rwhp and 782 lb-ft @36psi boost
Post Those Pictures & Join The Poll.
From Twins to Single 2jzgte to a little Powder Coating
PTB76 powered. Cool thread....glad it got brought back
