HELP Experts Supra TT suspenison
so i just picked up a set of supra tt shock n spring
bad part is one of the front is missing a top mount
could i use the sc top mount
also if i cut the springs just a LITTLE BIT for just a 2inch drop would it make a differnece in ride handling and make it super bouncy
shock n spring have 60k on it i got it from sum1 on this forum
For continuity, you might swap both your front SC mounts to the Supra shocks in the event that the rubber insulator is stiffer on the Supra mount: it could potentially unbalance the stiffness from left-to-right in the front if you had one mount from each vehicle on each of the two front shocks.
The most major difference between the Supra shocks and the SC shocks in therms of their geometry is the size of the rear spring seat on the Supra shocks, which is much smaller than the stock SC rear spring seat.
RyanR317
Sep 2, 2013 06:34 PM
Kakaroto
Jan 25, 2013 07:16 AM
Sweetser
Sep 28, 2006 01:02 AM
mrshabo
Feb 10, 2004 02:12 PM
