shakey steering wheel/shifter/brakes
i first noticed my steering wheel shaking a good amount on the highway about 3 weeks ago going about 75mph. then my shifter (auto) started shaking with it. then while on the brakes coming to a stop from about 55mph+, i feel something uneven in my brakes. i cant explain the brake problem but im starting to think the steering wheel shaking could be an alignment problem for the crash i was involved in about a month ago. but it doesnt shake all the time and the shifter hasnt shaken for a while now. any thoughts on what these problems could be?
All I can think of is unbalanced tires or bent rims. I would check your tires and rims to see if they check out ok. Unbalanced tires or a bent rim can give you a lot of vibrating o be or shakey ride. As for the brakes, check your rotors. When was the last time you had the brakes done? They may need to be resurfaced or replaced..
mi430
Feb 23, 2025 09:02 AM
rsxtc
Suspension and Brakes
Aug 19, 2005 10:58 AM
