5-Spd Trans..problem?
Old Apr 2, 2002 | 02:38 PM
LEx-Lvel's Avatar
LEx-Lvel
Default 5-Spd Trans..problem?
Hi, just got a 92 sc300 5-spd w/39k on it.. and the trans. blew after about I put 1500..My Bro. and I were learning how to drive a manual on it. We don't believe it was from the abuse from that the trans blew. What gives, all I read were high praise from the forum about 5-spd Sc's. do you know how much it is to fixed the trans.?
Old Apr 2, 2002 | 03:20 PM
quick's Avatar
quick
You probably inadvertently nuked it. If not you, then you should talk to your brother and figure out what he's hiding.
Toyota trannies don't go out at 39k miles without serious neglect or abuse. I've abused my tranny in my 85 for 10k miles (probably far worse than you could imagine) and it's still going strong at 139k miles.
Old Apr 2, 2002 | 03:51 PM
Bean's Avatar
Bean
CL Folding 1,000,000
possible that it was neglected or really messed with and run without any fluid before you picked it up
to fix it, just find the W58 5-speed from some toyota (SC300, Supra, etc) like in a junkyard or something and replace it.
you can find 5-speed trannies around for $500-$750 in good shape
your stock clutch and everything should be fine; just needs the tranny itself swapped out which isn't too hard (make sure you go with redline tranny fluid)
Old Apr 2, 2002 | 05:17 PM
awj's Avatar
awj
Bluegr*** Performance
Wow, a 92 w/ 39,000 miles? Sweet deal even if the tranny was fuxored. Replace it and check it out for any other signs of abuse. Change all the fluids, plugs, check belts and everything, at ten years old - w/ 39k it wasn't driven much.
Go easy on that thing huh? Drive her but love her too man, or you'll lose her. Like a woman.
Old Apr 3, 2002 | 11:39 PM
LEx-Lvel's Avatar
LEx-Lvel
Just got an Estimate from my local Lexus dealership...new clutch plus the rest of the other good stuff total up to $1400. Wow, that was expensive..any good trannie place in the Chicagoland area the won't charge about $800 in labor?
Thanks,
LEx-Lvel
Old Apr 3, 2002 | 11:45 PM
LEx-Lvel's Avatar
LEx-Lvel
oh...sorry guys, I jump the gun on this. Lexus mechanic called and said just the clutch blew. Not the trannies. Still $1400 is bit much to repair isn't it?
Thanks,
Lex-Lvel
Old Apr 4, 2002 | 09:04 AM
quick's Avatar
quick
Thanks,
Lex-Lvel
Bwahahahaha! What a fricking ripoff!
I'd shop around. That's insane. I could do it myself for less than $200 (not counting labor costs which I don't charge myself).
Old Apr 4, 2002 | 11:24 AM
SDSC300's Avatar
SDSC300
to replace the clutch, it cost me $575 parts were about 250, and they said 5.5 hrs @ $60 labor- 330 ... not too bad, but like quick said if you can do it yourself you can save quite a bit.
Old Apr 4, 2002 | 02:16 PM
Bean's Avatar
Bean
yeah clutch swaps are easy enuf on a front-engined tranny rwd platform
$1400 is WAY too much
you should get out doing $300 by yourself or $600 by a mechanic
Old Apr 4, 2002 | 02:18 PM
LEx-Lvel's Avatar
LEx-Lvel
Just got back from a place called Turbo Trans. They quoted me a $750. I guess that's not bad consider what the dealer quoted.
Thanks,
Lex-Lvel
zetec2vtec
Mar 7, 2009 11:21 AM
gnats
Jun 30, 2006 05:05 PM
sfsu
SC400 / 300 Classifieds
Sep 6, 2005 06:27 AM
wmulli
Mar 4, 2002 04:40 PM
