I have went through the wheel and tire thread i want personal oppinions please help.!
he wheels are 18x10 fronts with 18x10.5 rears. Offsets are SL +30 Type D in the rear, SL + 37 Type D in the front. The wheels sit flush as the pictures below should reflect, and they have a rather large 4" front lip and 5" rear lip.
I ran a 15mm spacer in the front to clear the turbo brakes, and have ground the calipers a bit when I was repainting them to make sure everything cleared. It's pretty tight in there. I can throw the spacer in if requested depending on price, but you will need longer wheel studs. My fenders are rolled in front and back.
You will need to run a spacer to clear turbo brakes, so please be aware of this, NA brakes should clear but you should double check and it is not my responsibility to verify. I have changed the wheels on the car and these are sitting in the garage taking up space.
i could but it would be a waste of time i just need to know with this offset would these wheels fit over na brakes? i know for sure i would have to roll my fenders.
