Turbo on an Automatic?
Old May 9, 2009 | 12:50 PM
megamarine's Avatar
megamarine
Default Turbo on an Automatic?
Ok everyone, I have to ask this, and call me stupid, but I have no idea how this works. Is it possible to get an effective Turbo system on an Automatic 2000 SC300? I want something that works, and I am really not willing to spend a ton of money tracking down pieces to convert my baby to a Manual, since my other car already is one, and I'd rather keep this as is. So, can it be done? Can I safely have a Turbo on my engine?
Old May 9, 2009 | 02:33 PM
ucfa4's Avatar
ucfa4
Absolutely it can and has been done.
Old May 9, 2009 | 03:48 PM
2jzlex's Avatar
2jzlex
There are probably more automatic turboed cars now than standards.
Old May 9, 2009 | 07:25 PM
huddleston's Avatar
huddleston
i believe boosted automatics actually hold boost more efficiently - this was explained to me once as i had a turbo kit designed for my 02 solara w/ automatic tranny. manual is preferred because a skilled driver can make the car much faster when compared to an auto. as long as you run a lower amount of boost ( i ran 6-7 psi) you should be fine. finding a tranny cooler may also help somewhat.
Old May 9, 2009 | 08:55 PM
2jzlex's Avatar
2jzlex
^^ Explain. Not disagreeing just wondering if you could shed some insight on it.
Old May 10, 2009 | 05:09 AM
Mr.NA_T's Avatar
Mr.NA_T
This is what i did, jus get a tanny cooler, change fluid, and stay at low boost and you should be fine
Old May 10, 2009 | 09:49 AM
2jzlex's Avatar
2jzlex
Originally Posted by Ryeno
The car auto shifts for you so their no loss of boost when you shift gears. Although this really only matters when you get to a point where the car is just too fast for you to be able to shift the gears. But to be fair the auto gear box is much more fragile then a manual. Which is why the stock r154 and the v160 can hold more power then the stock auto tranny.
Yeah this has nothing to do with the turbo being more efficient though. If you are talking about efficiency then you would take into consideration drivetrain loss or engine load comparing an auto to a stick or something to that effect. And "The car being too fast for you to be able to shift gears", well I'm just now sure what in the hell that means, no such case and that would depend on what you're using the car for anyway.
Old May 10, 2009 | 06:56 PM
Durrr's Avatar
Durrr
CL Folding 25,000
When you shift with a manual, you have to at least somewhat let off the gas which slows the entire reaction down. With an automatic, there's not letting up of the throttle, and consequently, load on the engine so boost is held in between shifts. That is what he's talking about. The only thing about an automatic is a much larger % of drivetrain loss (about 8% on average) that doesn't make it to the wheels.
Old May 13, 2009 | 10:51 PM
DKNY0331's Avatar
DKNY0331
im trying to figure out toyotas but the 3 in a340e might mean the strength of the tranny, like 3 means 300lbs of tq.. i know on ford some of the tranny models use the number to identifie how much a tranny can hold. i know the 4 in 340 mean 4spd and e is electronic. little of topic but thought id share something i heard in school. the ford should be a fact the toyota is just a theory of mine.
Old May 13, 2009 | 11:44 PM
2jzlex's Avatar
2jzlex
I don't think anyone got it, oh well.
Old May 14, 2009 | 03:37 AM
Mr.NA_T's Avatar
Mr.NA_T
lol
Old May 14, 2009 | 08:45 AM
Punky's Avatar
Punky
Member LRD is making around 500whp on an automatic that's been slighty modified an it's holding up fine
Old May 14, 2009 | 09:21 AM
lexforlife's Avatar
lexforlife
auto are faster off the line no doubt , but manuels have more control of boost , a auto will shift a predetermined shift points and in most cases just before the sweet spot of the turbo whereas manuel you can go to red line ( and for us that are on aem's redline is 7500 to 8k) if you couple the manuel with a dbb turbo so transient response between shifts dont deminish you r golden
i love manuel period
Old May 14, 2009 | 10:21 AM
hyjaxx's Avatar
hyjaxx
That definitely depends on the automatic you're running Lexforlife. Um- op, you can run a turbo but don't go crazy- you don't wanna blow the core (you'll need to send it to BoostLogic if you wanna go bigger and stay auto). Just listen to huddleston- he's got it right. You won't need anything over the top.
Old May 14, 2009 | 05:38 PM
F4A22's Avatar
F4A22
I'm running auto and its very consistent.Also cheaper to replace or buy a race tranny.
