Preventive Maintenance (timing belt)
Old Mar 20, 2002 | 07:41 AM
krypto's Avatar
krypto
Default Preventive Maintenance (timing belt)
My ride has 93k on the odo...Going to take it in next month to have the timing belt replaced.
1. How much should I expect to pay?
2. Any other 'potentially very bad' if goes out parts, I should replace?
Thanks
Old Mar 20, 2002 | 08:54 AM
VQT's Avatar
VQT
Default Re: Preventive Maintenance (timing belt)
Thanks
Remeber to tell them to replace the water pump also. Timing belt, cam seals, two idlers. Dealer will charge you ~$1000
local garage ~$700. Its about 4-5 hrs labor charge.
Old Mar 20, 2002 | 10:11 AM
joelchicago's Avatar
joelchicago
As long as you're in there with the covers off, if you didn't get the distributor caps and rotors changed at 60K, do 'em then. Cheap parts, easy replacement, worth the $40-50 in parts! Replace the serpentine as well, again, if it hasn't been done. Have them take a peek at the coolant hoses too. Make sure they are still in good shape.
Not a cheap belt to replace, based on my work on the car. At my favorite local independent shop, close to $550 to do it.
Old Mar 20, 2002 | 10:45 AM
quick's Avatar
quick
Just to be clear it doesn't matter if your timing belt goes out ... they're non-intereference engines and it won't hurt a thing. Your car will just stop running until you replace it.
HTH.
Old Mar 20, 2002 | 10:59 AM
TheKevin's Avatar
TheKevin
CL Folding 25,000
or you could do it yourself. buy the timing belt from Lexus. get the factory service manual and DIY. you'll save a lot of money and learn to replace the TB.
Old Mar 20, 2002 | 11:07 AM
krypto's Avatar
krypto
?? okay I am mis-informed...I thought if the timing belt went out it was big trouble...
"they're non-intereference engines and it won't hurt a thing"
really? If this is true maybe I'll wait and buy some Borla's instead!!
Old Mar 20, 2002 | 11:44 AM
quick's Avatar
quick
I would triple-check this with someone who owns one, but according to these threads the 1UZ-FE is non-interference:
https://www.clublexus.com/forums/sho...oninterference
https://www.clublexus.com/forums/sho...5&pagenumber=2
You could even call your Lexus dealer to ask.
HTH.
Old Mar 20, 2002 | 12:24 PM
krypto's Avatar
krypto
Thanks...after readin the posts you referenced...I'm convinced it's non-interference....
Old Mar 20, 2002 | 01:18 PM
Camshaft's Avatar
Camshaft
Do those price ranges apply to the SC3 as well?
I need to change the:
Plugs
Wires
Timing Belt
Water Pump (presuming)
power steering fluid
Coil?
Old Mar 21, 2002 | 04:26 AM
VQT's Avatar
VQT
Joe,
Is $550 included parts?
I paid $300 cash labor to a Toyota Certified Mechanic and two of his friends to do the job in the dealer shop (it's a side job, after work hr).
Makiavelo7
GX - 1st Gen (2003-2009)
12
May 18, 2017 02:01 PM
Dallasguy1
Aug 15, 2016 11:41 AM
Vito 06430
Aug 20, 2012 09:59 AM
immax01
May 19, 2012 05:16 PM
Red Bully
Aug 16, 2008 10:21 PM
