Sludge normal?
Old Apr 27, 2009 | 12:01 PM
Neucorp's Avatar
Neucorp
Default Sludge normal?
Just finished replacing my valve cover gaskets on my 400 with 150,000 miles. While I had the valve covers off, I decided to clean them up as best I could. I noticed lots of caked on sludge...almost like the oil had been burnt. I spent hours cleaning them.
Is this normal? Any recommendations on preventing this in the future? Are there any additives that will clean areas I couldn't get?
Thanks!
Old Apr 27, 2009 | 05:43 PM
1jztts's Avatar
1jztts
seafoam it
Old Apr 27, 2009 | 07:42 PM
StiCk3's Avatar
StiCk3
no matter what anybody says, old engine or new engine, sludge is not normal.
First additive that comes to mind is seafoam. There are some others out there, but I've only used seafoam. Oil drain is very dark after running it through, so i guess it's doing its job.
Old Apr 28, 2009 | 07:28 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Seafoam is the answer.
Old Apr 28, 2009 | 08:22 PM
Jewcano's Avatar
Jewcano
No Sir, I Don't Like It
CL Folding 1,000,000
Make sure everything is NICE and tight. If it's not, and that sludge you cleaned off was actually helping seal things up, cleaning it up and breaking it down might not have been the best for the engine. Unless you did a complete engine breakdown/cleaning/rebuild, then that's another story. If seafoam is started early and done every so often, I could see the benefit, but when you first start it on a high mileage motor, you're breaking down deposits that have been sealing the motor up on the inside, and sending those deposits everywhere. All you have to do is read about it.
I seafoamed my SC4 when I had it, and it had over 150K on it. She blew some nasty smoke out (that was normal), and after an oil change, and sparkplug change, she hadn't really changed that much to be honest. Some folks will swear on the stuff and tell you it's a night and day difference. However, when it comes to a high mileage engine, as they say "if it ain't broken, don't fix it".
txsilverad
Apr 27, 2019 03:11 PM
richonline
RX - 1st Gen (1999-2003)
12
Jun 22, 2011 08:04 PM
jayrocem
17
Mar 31, 2010 07:24 AM
buci
Mar 14, 2009 09:19 AM
Taka
Apr 13, 2002 08:36 AM
