spoiler light
Old Apr 13, 2009 | 02:06 PM
sc4002soar's Avatar
sc4002soar
Default spoiler light
anyone know how to replace or fix the led brake light on the spoiler?
Old Apr 13, 2009 | 02:11 PM
AD_SC3's Avatar
AD_SC3
Try making sure the wire is grounded on something. I had this problem when I first got my Sc.
Old Apr 13, 2009 | 02:37 PM
ThomasGS4's Avatar
ThomasGS4
Mine was simply unplugged
Old Apr 13, 2009 | 03:01 PM
UZZ30-SC4's Avatar
UZZ30-SC4
Look for cut wires
Old Apr 13, 2009 | 04:35 PM
Blkexcoupe's Avatar
Blkexcoupe
Look for rust on the circuit board. Some of the connections on mine were damaged.
Old Apr 13, 2009 | 05:51 PM
Hil's Avatar
Hil
If you need to remove the led, then remove the trunk lining on the trunk, revealing a couple screws for the spoiler. Unscrew those and pop the spoiler off. Then you can unscrew the light
Old Apr 13, 2009 | 06:18 PM
texan_176's Avatar
texan_176
What year is your SC?
The 97+ LED strip is a POS cause it leaks and allows water/moisture to leak inside and ruin the electrical board.
Mine only had 5 working LEDs when I got it.
If you have a 97+ then find any LED strip that is about 15.5 inches long in a junkyard. I used one from a Mitsubishi Eclipse I paid $3 for.
Basically this is the gist of it:
Use an exacto knife to open up the OEM strip housing once it is out of the spoiler.
Cut the wire or desolder as close as you can to the circuit board.
Break the donor car LED strip housing.
Use a small drill bit on the new board to match the mount screw locations in the stock board. Be careful not to drill into a circuit.
Solder the old wire with stock plug to the next strip after you desolder the old wire from the new strip.
Seal the OEM housing with silicone and allow it to dry overnight so it does not collect dirt/dust/water.
Plug it up and mount.....you should be golden.
The stock strip assembly is about $170 from the dealerships and will leak again so don't go that route. Some people have cleaned the repaired their stock circuit board and installed new LEDs on it. That seems like too much work for me when a smiliar result can be had for less than half the time.
Of course, test your junkyard LED strip before you buy it with a hot battery.
92-96 strips are not notorious for problems like 97+ but this "fix" can be used on pretty much any kind of car.
Old Apr 13, 2009 | 06:32 PM
Blkexcoupe's Avatar
Blkexcoupe
I did that and after about 9 months 5 of the new LED aren't working again.
Old Apr 14, 2009 | 03:59 PM
sc4002soar's Avatar
sc4002soar
i have a 92...will try removing the spoiler den. its the spoiler that looks like its molded into the trunk
horent135
Jul 7, 2011 09:03 AM
Daihuy
Apr 24, 2011 01:58 PM
Shayy
Feb 21, 2011 06:22 AM
97-SC300
SC400 / 300 Classifieds
Mar 23, 2009 09:17 PM
THE_CEO
Jul 15, 2003 05:01 AM
