(DIY) Centre Console Removal
Old Apr 13, 2009 | 08:56 AM
JZCHAOS's Avatar
JZCHAOS
Default (DIY) Centre Console Removal
The Search Engine is not user friendly at all when you looking to get it down NOW!! Insted of spending hours searching. Asking a question sometimes gets you a smart A$$ Remark!! I had to Google the Info.
Firstly, put the gear selector into 'N'. This will require you to press the small red button next to the gear selector so that you can move the gear out of park with the ignition off. Now you know what the red button's for! Don't forget to make sure the handbrake's on. Then slide down the plastic sleeve at the bottom of the gear stick, and undo the two screws, it should then pull straight off.
Then you need to remove the black plastic gear selector panel, to do this you need to unclip 4 clips, in each corner of this panel. This can be fiddly first time round, but once you've done it you'll be popping it in and out no worries. Retain the felt pads around the clips and be sure to replace them properly afterwards for a rattle-free future.
Then unclip the block connectors for the lights and switches. You might find a Japanese coin down inside somewhere, both myself and Iain did!!
Open the fliptop cupholder at the rear of the assembly and pull the whole thing upwards. It should come out with a bit of persuasion. You will now see six screws on the lower section which hold the entire surround in place. Undo these and you should now be able to lift the surround up and towards the front. There are more connectors to watch out for at top of the surround, next to the aircon/stereo unit. These will also have to be disconnected if you want to remove the surround entirely.
The aircon headunit/stereo all comes out in one cage by undoing 4 screws. If you are going to atttempt to drive the car with the centre console out, leave the centre block of the aircon connected, otherwise this affects the ECU. Also, if you leave the hazard warning light switch disconnected, the indicators will not operate.
Needless to say, putting it all back together is the reversal of removal. Care should be taken to ensure that you don't drop any of the screws down inside the gearbox housing, or behind the air conditioning unit.
Old Apr 13, 2009 | 09:25 AM
durtysc300's Avatar
durtysc300
is your car RHD? i wonder if that little red button is a JDM thing because mine doesn't have one but thanks for the diy! it took me forever to figure out how to do it my first time..and i also found a japanse coin haha
Old Apr 13, 2009 | 09:31 AM
Hil's Avatar
Hil
Yes.. searching is a b*tch. But we all go through it. I myself have searched for a good chunk of time myself and I just subscribe to any and all helpful threads I find. That's a good tip, subscribe so ya don't have to kill yourself searching for something later.
Nice work though!
Old Apr 13, 2009 | 03:54 PM
TheMole's Avatar
TheMole
Might want to add a search tag for "Center" as some people spell it this way. Also, I had no trouble finding previous threads for removing the center console with a quick search. Are you guys searching under 'titles only'? Often times searching 'entire posts' will give you too much results.
Good job on the pics though since the other threads do not have pics.
Old Apr 13, 2009 | 04:12 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Could just be you, doc. Every single thread that came up searching those three words had pics and instructions. ALL of them.
Old Apr 13, 2009 | 04:24 PM
MongooseGA's Avatar
MongooseGA
Just for the sake of future searches, we may want to change the name of this thread from "Centre" to "Center".
Despite the illiteracy of most of the SC forum members, this may help a tad ;-)
Old Apr 13, 2009 | 06:14 PM
SClean4's Avatar
SClean4
i will need to do this if i ever get a black center console. ty
Old Apr 13, 2009 | 08:32 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Nice write anyway.. Another good DIY! Thanks
Old Apr 14, 2009 | 12:43 PM
ShiftyD2k's Avatar
ShiftyD2k
nice job..
Old Apr 14, 2009 | 02:18 PM
2.5tsoarer's Avatar
2.5tsoarer
So true my friend...
Old Apr 14, 2009 | 11:26 PM
horent135's Avatar
horent135
The red button is on JDM, our is black button on top left below the heated seats switches
Old Apr 15, 2009 | 02:26 PM
carbophat's Avatar
carbophat
I have found this true on every auto forum I am on...
Old Apr 15, 2009 | 02:46 PM
Teal Sc400's Avatar
Teal Sc400
Default DIY Link of Dreams
JZCHAOS, Nice DIY...should have asked another native MD, here are some other DIY links that might be of help in your future.
https://www.clublexus.com/forums/sc-...ollection.html
Old Apr 15, 2009 | 06:20 PM
scENFORCER's Avatar
scENFORCER
It took me a long time to figure out how to get at those 2 screws in the very first step! But I eventually figured it out.
What I need now is to figure out how to get the ENTIRE console between the two seats out. I cant figure out how to get at the 2 screws holding it down at the front, and there seems to be a few invisible screws holding it down from the back somewhere. I've searched, and found a few threads here and there that outline it, but I still cant seem to translate it into any success in my car ..or maybe I'm just a dumba$$ lol
Old Apr 16, 2009 | 06:41 AM
blacice83's Avatar
blacice83
Dude i've been searching for this for so long now and you have been my savior,lol. This was the entire reason i joined this forum but it came to be more helpful then i orginally intened.Thanks alot.
