TPS sensor clip = Car not running right
I was having a problem with my car a wile back and it was getting to much fuel and missing really bad.So the other day I started messing with my wiring on my sc300 and every time I pulled the wires that go to the TPS sensor it stopped missing.So then I looked at the clip that clips to the TPS sensor and it was broken.So I am trying to replace the TPS sensor clip but I was going to see if the dealer sold it but I cant find a Lexus dealer that sells them online.Do you think if I call the dealer they will have it?And if the clip doesn't work I am going to replace the wiring harness.THANKS
junkyard is your friend here, cut the end off the broken one and bring it to the junkyard - many camary, es300, any toyota really will have the same plug.
dealer will also be able to order it for you, should be ~ $12 for the plug from them and then $5 per wire with pins on them (so ~ $32 total)
StarGS3
Oct 19, 2017 06:06 PM
