checking codes
Old Mar 17, 2009 | 11:51 AM
KrazeMatik's Avatar
KrazeMatik
Default checking codes
ok so i decided to check the ecu code and when i have the car to on position both engine and o/d light flashes... is this normal?
Old Mar 17, 2009 | 12:15 PM
KrazeMatik's Avatar
KrazeMatik
ok if im only checking the engine light it gives me 3 flashes pause then 1... then i looked up the codes for obd1 it says
31 Air Flow Meter signal (Vacuum Sensor signal). where do i find this at?
Old Mar 17, 2009 | 07:14 PM
0l33l's Avatar
0l33l
I've had the same problem:
https://www.clublexus.com/forums/per...stic-mode.html
Old Mar 17, 2009 | 07:29 PM
KrazeMatik's Avatar
KrazeMatik
omg thats what my is doing also i was going to make a video too. so have you found out what the prob was? for me i feel like the car is sluggish and doesnt want to get into gears... its not slipping though but just very slow responce... however i did replace both of my spark plugs and wires but still have this problem....
Old Mar 17, 2009 | 08:56 PM
0l33l's Avatar
0l33l
I don't think the blinking O/D light corresponds to the same codes. I mean mine flashes 42, which doesn't make sense, as I'm not running a 7M-G(t)E. I haven't followed O.L.T's advice yet and reset the ECU. I know that the EGR problem will resurface anyways (until I remove it )
AlaskanLS
Aug 9, 2018 09:52 PM
KrazeMatik
Apr 6, 2009 12:26 AM
mrtentacle
Jan 26, 2007 04:49 PM
VehicularL
Feb 4, 2005 10:03 AM
danreiner
Jan 7, 2005 09:00 PM
