Na-t done, Code 24 25 31
Old Feb 21, 2009 | 01:02 PM
shuiyuan's Avatar
shuiyuan
Default anyone got CEL from MAF and air temp sensor circuit after NA-T
after the Na-t done last week, the CEL came on after drove around 30 miles, run the code got:
24 air temp sensor circuit open short
25 lean exhaust
31 air flow meter circuit open or short
never had CEL before the NA-T car doesn't have any Cat and untuned.
Old Feb 21, 2009 | 01:58 PM
shuiyuan's Avatar
shuiyuan
SAFC installed and resetted to default setting.
i know i need get the car tuned asap, but i don't know if the airtemp and air flow meter caused by the SAFC.
if the MAF sensor went bad, then it will be waste to bring the car to dyno tune.
what should i do first?
Old Feb 24, 2009 | 07:35 PM
shuiyuan's Avatar
shuiyuan
nobody had cel after Na-t for maf?
Old Feb 24, 2009 | 10:54 PM
booja's Avatar
booja
if you never had a CEL on before id check the safc and make sure its wired right. i know it needs the airflow meter as an input and then the safc outputs it into the ecu... make sure that wire is not shorting out or loose.
oh and on the MAF it can only be put on one way... im not sure if its blow through or the other one.
now for the other 2... the afc does not interfere with it so i cant help you there. but if the maf is not reading right it can cause the lean code because the maf maps out the fuel
Old Feb 25, 2009 | 12:48 AM
shuiyuan's Avatar
shuiyuan
i don't have cat on my car, will the bottom o2 through a code? my car is 1992 so odb1
SC93
Jul 30, 2013 08:06 AM
vwynn
Oct 23, 2011 04:54 PM
1lexus2c
Jun 4, 2011 10:10 PM
shajbot
Feb 25, 2009 10:38 AM
snidehocke
Feb 5, 2008 04:51 PM
