o2 sensor what are ..?
Old Feb 19, 2009 | 10:48 PM
MERXUS's Avatar
MERXUS
Default o2 sensor what are ..?
how do you know when your o2 sensor is gone?
my car is hesitating just slightly on the take off...; i got new plugs, new oil, all new fluids, etc. Could it possibly be my o2?
Old Feb 19, 2009 | 11:46 PM
sc300s13's Avatar
sc300s13
could be.....if they are bad sometimes they cause you to have bad air fuel ratios...also check your maf (mass airflow) clean it
Old Feb 20, 2009 | 04:28 AM
RolxuSC400's Avatar
RolxuSC400
If your o2 sensor is bad it will through a code. Not likely o2 sensor.
Old Feb 20, 2009 | 07:54 AM
StiCk3's Avatar
StiCk3
It could also be a TPS sensor as well. Clean the MAF first as that is usually the most vunerable to the elements and the easiest to fix. A missing 02 sensor will almost immediatley throw a code when it "goes missing"
Old Feb 20, 2009 | 04:58 PM
topdog849's Avatar
topdog849
but mines a 93' OBD1. my cars starting to get ****ty gas mileage, 200 miles last fill up. can i use a multi-meter to check o2 sensors?
Old Feb 20, 2009 | 07:00 PM
matrixgts's Avatar
matrixgts
take it to autozone they will check it for you no charge
Bluv
Nov 9, 2015 01:28 PM
st1013
Jan 19, 2015 03:32 PM
techiedude
May 2, 2012 06:57 PM
palaka
RX - 1st Gen (1999-2003)
Feb 21, 2008 10:27 AM
Garymkrieg
Jul 17, 2006 11:02 AM
