Debaging the SC?
Old Jan 31, 2009 | 09:57 AM
  #31
P.R.S.22's Avatar
P.R.S.22
Depends on how close you were applying the paint that its dripping. You need to be like 6 inches or so away and do some quick strokes with the spray back and forth. 2 coats should be good enough after primer. If your getting drips you can always sand it off and redue it again.
Old Jan 31, 2009 | 11:37 AM
  #32
Amini9's Avatar
Amini9
CL Folding 200,000
Thanks for the response. Either in between the time that i didnt look at it, the drippings dropped onto the carboard that i was working on, or it absorbed itself..
i put on the black, waiting for it to dry. its somewhat cold, so its taking a while to dry :/
Old Jan 31, 2009 | 11:42 AM
  #33
P.R.S.22's Avatar
P.R.S.22
No problem...remember to take your time with this if you want it to come out right. There is no rush for quality work.
Old Jan 31, 2009 | 11:50 AM
  #34
Amini9's Avatar
Amini9
CL Folding 200,000
Will do.
The 3M tape- how do i put this on the badges? Line it up , stick it on the badge and use a razor to cut the excess tape??
also, my brother was telling me once i paint these and it rains, the paint will just come off and told me to get some clear coat?
true? or will the paint stay?
edit: i just looked at them... still wet and has tons of mini bubbles everywhere. ugly, but i tried so.. its MY bubbly badges
Old Feb 6, 2009 | 03:14 PM
  #35
felixsc300's Avatar
felixsc300
Clearcoat is a good idea on high-wear areas (the front of the vehicle). You are correct for the process of 3M tape usage.
I stuck on my emblems without 3M tape since I forgot to buy a roll and all the stores were closed (nighttime). I never got around to buying that roll of tape, but the emblems stick and stay just fine.
Old Feb 6, 2009 | 04:48 PM
  #36
supralative's Avatar
supralative
Do the Lexus on the driver side and the SC300 in the center have any indentions in the body once they are removed. I was going to leave the Circle L emblem and just remove the other two as long as there is no sign on the body after the emblems are removed.
Old Feb 6, 2009 | 04:56 PM
  #37
P.R.S.22's Avatar
P.R.S.22
The Lexus on the driverside has holes behind it but the SC 300 badges do not have holes behind them.
Old Feb 6, 2009 | 06:52 PM
  #38
Amini9's Avatar
Amini9
CL Folding 200,000
after i was done, for my SC400, it has holes on all of them.
Old Feb 6, 2009 | 07:36 PM
  #39
P.R.S.22's Avatar
P.R.S.22
That might be the case for 92 to 96. I forgot to mention that.
Old Feb 6, 2009 | 08:08 PM
  #40
felixsc300's Avatar
felixsc300
Correct. The 'SCX00' emblem is mounted on the rear bumper with guide pins, and the 97+ 'SCX00' emblem is mounted on the right corner of the trunk.
Old Feb 8, 2009 | 08:25 AM
  #41
supralative
OK
so it seems anything on the urathane bumper will have mounting holes
while anything on steel will not
Old Feb 8, 2009 | 03:52 PM
  #42
Amini9's Avatar
Amini9
CL Folding 200,000
well everything that i did had holes.
AWB55
Apr 28, 2024 06:10 PM
Armitutz
RC - 1st Gen (2015-present)
Jul 31, 2015 06:03 AM
JProdun
Apr 20, 2014 07:36 PM
twenty
Apr 17, 2011 07:20 PM
