stance coilover owners I need some help
Old Jan 25, 2009 | 10:59 AM
quickex99's Avatar
quickex99
Default stance coilover owners I need some help
I am a gs owner but I know alot of you sc guys have these. I just installed mine and I'm having trouble adjusting the rears.. I have them cranked all the way up and even extended the lower adjustable mount (so the strut got longer) and the thing is still slammed!! I'm trying to raise it up.. Am I missing something? Thanks in advance!
Old Jan 25, 2009 | 11:11 AM
Biggu's Avatar
Biggu
try turning the whole shock body so that it goes up.
Old Jan 25, 2009 | 03:11 PM
TheMole's Avatar
TheMole
IIRC, the Stance's have 2 ways of adjusting the height. Either by the spring perch or the shock body as mentioned above. One of these is probably still adjusted too low.
Old Jan 25, 2009 | 04:23 PM
quickex99's Avatar
quickex99
thanks guys.. I'm just gonna mess with them tommorow after work.. For how low I am they ride amazing!!
Old Jan 25, 2009 | 04:53 PM
5sp_jzz30's Avatar
5sp_jzz30
yep. they are pretty good
i love my stances
Old Jan 30, 2009 | 05:30 PM
sgunitkc's Avatar
sgunitkc
anybody experiencing any clunking noises in the back while hitting any sorta bumps on the road? I've had stances for a while and I've had the noise since I changed em.
Old Jan 30, 2009 | 07:26 PM
Blkexcoupe's Avatar
Blkexcoupe
How are your bushings?
Old Jan 31, 2009 | 07:28 AM
Biggu's Avatar
Biggu
check to make sure the spring perch is tight, if not you can tighten those up. mine used to do that but the spring has some wiggle room, bring the perch up so its tight and cant move and it fixes your problem
Old Jan 31, 2009 | 08:20 AM
camberSC's Avatar
camberSC
I have the same problem even after changing the bushings. I have read that people with other makes do too.... I can live with it though... sometimes its a little embarrasing.
aEO 37
Suspension and Brakes
20
Jun 16, 2017 06:56 PM
niccuhles
Oct 20, 2011 09:46 AM
kponti
Sep 22, 2010 06:22 PM
TKLEX300
Feb 10, 2007 09:06 PM
