Removing interior trim pieces
Old Jan 20, 2009 | 01:06 PM
durtysc300's Avatar
durtysc300
Default Removing interior trim pieces
how do you remove the trim piece that goes around the stereo and climate control that holds the volume **** in place?...gonna fill that volume **** hole since i no longer need it
Old Jan 20, 2009 | 01:14 PM
shajbot's Avatar
shajbot
Pull out the penny cup at the end of that trim console, you'll see some screw. Remove them. Pop out the gears plate, disconnect 2 harnesses, remove more screw under there. Then pull the trim out. To remove the gears plate you probably have to remove the shift **** by removing two screws on the shift know after sliding the plastic part at the bottom down.
Old Jan 21, 2009 | 11:23 PM
ShiftyD2k's Avatar
ShiftyD2k
Climate Control Removal
Slide sleeve down from bottom of shifter to reveal two screws and remove screws. Shifter will lift off.
http://www.lextech.org/images/climateremoval1.jpg
Pull cupholder upwards grabbing from the inside of the cup for leverage. It is only held on with pressure tabs so it will lift out, may be tough to lift out, may not be. Try lifting from the back flap side where the pressure tabs are.
http://www.lextech.org/images/climatemoval2.jpg
Remove screws from under cupholder.
http://www.lextech.org/images/climateremoval3.jpg
Pop shifter plate off, again only on pressure tabs like the cupholder. Unplug plate from car and remove the screws from the back and front near the ashtray.
http://www.lextech.org/images/climateremoval4.jpg
Now simply lift the rear of the console cover and pull backwards to slide console cover out of console. Then unplug ***** and cig plug.
The rest is self explanatory as it is just screws holding the radio cage and of course unplug the climate and radio.
steamboatr
May 17, 2015 07:45 PM
chelli
Sep 27, 2010 02:53 PM
SCupra300
Aug 31, 2010 06:04 PM
lexman52
Oct 30, 2009 02:04 PM
Arun
GS - 1st Gen (1993-1997)
Apr 30, 2003 06:07 PM
