Need intake help fast!
Old Dec 2, 2008 | 10:14 PM
Inzane089's Avatar
Inzane089
WTF wow... im 17 years old and absolutly retarted... honestly guys i love you... thanks so much.. cuz without you guys id be punching my self in the head
ima do that right now just to make sure... post in a min BRB
Old Dec 2, 2008 | 10:15 PM
rwdanthony's Avatar
rwdanthony
read my previous post haha you can forget about reseting the ecu/ disconnecting the battery, its not needed.
also when its done and fixed. PM me the feedback of this kit and if you hear any whistle with your new intake. thanks!
Old Dec 2, 2008 | 10:18 PM
OneJay's Avatar
OneJay
I used to have the same one on mine. Its a great part for the price.
Old Dec 2, 2008 | 10:21 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
I know it's too late for him, but this type of air intake can actually hurt performance more than it helps... no longer will it be sucking in cooler ambient temperature air, but hot, engine bay air... there may be less restriction, but the higher temps will negate that...
When they test this on a dyno though, they open the hood and put a fan right on top blowing nice cool air, so it does show a slight power increase...
My advice - build a cold air box to run cool air to the filter and block it off from the rest of the engine compartment... then... wrap the pipe in heat wrap - because it is aluminum it will get hot with engine compartment heat and act like a heatsink to warm the incoming air even more - another bad thing... the plastic/rubber stock tubing actually insulates the air to an extent...
Old Dec 2, 2008 | 10:24 PM
OneJay's Avatar
OneJay
But it sounds cool.
He's right though. Try making some kind of heat shield or air duct. product.sc has an air duct that I have yet to see pics of. Hint hint* I'll post a pic of my heat shield for you if I can find it.
Old Dec 2, 2008 | 10:27 PM
rwdanthony's Avatar
rwdanthony
thanks for the factual input, but that information is pretty much well known. and one thing you forgot to mention is how the resonators help on stock intakes, they act as a reservoir tank on unused air, and can be used when the engine needs it under load. im actually just getting little feedbacks for self curiosity, for my own n/a applications. im actually conducting some new stuff for my sc. hows a ARC air chamber box sound? with 3 inch piping? and a cold air feed? haha
Old Dec 2, 2008 | 10:28 PM
Inzane089's Avatar
Inzane089
You guys i just switched it and it runs like a million bucks... i took it for a spin at 1:20 in the morning and opened her up... i felt it, and i mea honestly... it sounds like heaven is singing out my intake and exhust... so amazing... thanks guys once again... its now 1:30 and i gotta go wake at 5:50 for school... haha goooood night
Old Dec 2, 2008 | 10:31 PM
Inzane089's Avatar
Inzane089
where should i be seaching on more info on creating the box to block off the engine bay heat? if i tried it by myself ill probably mess up my baby like i just did tonight haha
Old Dec 2, 2008 | 10:37 PM
rwdanthony's Avatar
rwdanthony
just look at random cold air intake system pic's youll get it eventually. haha no worries about it though, atleast we got it resolved.
the idea is to keep hot air away from the intake. as cold air is more dence. [more oxygen in hense]
get that idea right, and youll learn it just fine.
Old Dec 2, 2008 | 10:38 PM
Inzane089's Avatar
Inzane089
thanks alot man.
Old Dec 2, 2008 | 10:42 PM
OneJay's Avatar
OneJay
Here are a couple of the heat shield I had. Just aluminum with heat tape over it.
Here is another guy's heat shield
Old Dec 2, 2008 | 10:51 PM
Inzane089's Avatar
Inzane089
oh ok.. nothing to complicated... thanks again bro
GXBaron
GX - 1st Gen (2003-2009)
May 12, 2010 06:06 PM
sc400nitro
Nov 9, 2008 04:16 PM
Lvangundy
Nov 28, 2002 05:34 PM
C-Tang
Jul 29, 2002 08:00 PM
lex400sc
Jan 25, 2002 08:48 AM
