Uneven Suspension Settling
Old Oct 20, 2008 | 05:33 AM
Enigma8246's Avatar
Enigma8246
Default Uneven Suspension Settling
In March of this year I installed Tokico shocks and an Eibach pro spring kit on my ’93 SC3. I have some uneven settling in the rear. With 19” rims (and non-stretched rubber) I have about two inches between the tire and the fender on the right side and anywhere from a half to one inch on the left side. The weight distribution in the trunk is even (and I wouldn’t think with the stuff I have in my trunk it would even make a difference). I have had minor rubbing (not even enough to call a problem since it is rubbing the outside of the tire and doesn't appear to be doing any damage) but i'm paranoid about it. In a few weeks I’ll be doing my brakes and was gonna poke around on my suspension to try to find out what’s up with it. Does anyone have a suggestion on what to check/look for?
Old Oct 20, 2008 | 08:57 AM
TheMole's Avatar
TheMole
Was it uneven right after you installed the suspension or it happened over time?
Seems like that is a major height difference between sides.
Double check to see if the endlinks were installed correctly.
Old Oct 20, 2008 | 09:06 AM
OneJay's Avatar
OneJay
Also check to see if the springs are seated correctly on the shock
Old Oct 20, 2008 | 10:25 AM
Enigma8246's Avatar
Enigma8246
I don't think it was like that when i first put them on. It may have been and i just didn't notice it because it wasn't so close to the tire.
Will do. I really hope i don't have to remove the strut because its a pain
Old Oct 20, 2008 | 11:09 AM
OneJay's Avatar
OneJay
You don't necessarily have to remove the strut. Just jack up the car, take off the wheel, and if it's not seated correctly, just compress the spring and turn it. It worked on my buddy's Scion.
Old Oct 23, 2008 | 07:14 PM
Curry's Avatar
Curry
CL Folding 25,000
I have the same problem with my tanabes. The right side is higher than the left, but just the rear. The fronts are fine.
Lets say the spring is seated correctly, endlinks could cause that problem too? I'm pretty certain my endlinks in the rear could be bad cause everytime I hit a bump, I hear a clunk....
Anything else I should check?
Old Oct 24, 2008 | 01:17 AM
TheMole's Avatar
TheMole
Definitely check the rear suspension components for that clunking sound. Could be just a loose nut on one of the endlinks. Not sure if a worn endlink can alter the height of a corner, but an improperly installed one might be able to. It happened to a member just have to find the thread.
Old Oct 24, 2008 | 01:55 AM
OneJay's Avatar
OneJay
I had a clunking noise from the back, and it was a blown shock. Check yours if they are old.
Old Oct 24, 2008 | 06:42 AM
Curry's Avatar
Curry
CL Folding 25,000
I wouldn't doubt the shocks are old. For all I know they are probably the ones that came from the factory... LOL
I plan on doing over the entire suspension in a week or two so all the shocks are going anyway.
Old Oct 24, 2008 | 05:01 PM
Curry's Avatar
Curry
CL Folding 25,000
These pictures show the difference in height...
Right Side:
Left Side:
Old Oct 24, 2008 | 05:59 PM
TheMole's Avatar
TheMole
That is quite a difference. They are lowered on Tanabe nf210?
Old Oct 24, 2008 | 06:22 PM
Curry's Avatar
Curry
CL Folding 25,000
Yes sir! Tanabe NF210's. I didn't think anything of it after the install. Then i started to notice the clunking in the rear. After it didn't settle right I knew something was up.
EDIT:
All the clunking I have been hearing is definitely coming from the LEFT side of the car (Lower side)
Old Oct 26, 2008 | 03:09 AM
sc-driver's Avatar
sc-driver
I'm having somewhat of the same problem. It is weird because my right side is higher then my left side by about a finger and a half. I'm running on supra eibachs. I have a friend with an IS250 on eibach springs aswell and same thing with him. Maybe its because the left side might be a bit heavier. idk?
I adjusted the seat position of the springs a lil and it helped. It looks a lot more even now, but otherwise the only way I see it getting perfect is through coilovers!
well, good luck man
Old Oct 26, 2008 | 04:41 AM
davidv433's Avatar
davidv433
I did the tein ss on my car at my job, and i hear a loud clunking too. im thinking its the lca bushings, cus now i know theyre shot. Also replaced driver side endlink, should have replaced both at the same time.
Old Oct 27, 2008 | 08:07 AM
Curry's Avatar
Curry
CL Folding 25,000
Checked the spring and it is seated correctly. Sounds like it could be the shock that's causing the left side to sag lower than it should, causing the right side to lift up?
