Steering Wheel Clicks When Turning...Help
Old Oct 18, 2008 | 06:32 PM
kingrich's Avatar
kingrich
Default Steering Wheel Clicks When Turning...Help
Re-installed steering wheel but whenever turning the steering wheel to drive, it clicks.
Cruise Control stops working and sounds like the wires inside are tangled?
Help?
Old Oct 18, 2008 | 06:35 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
So take it back apart and fix the airbag spring you didn't re-install correctly.
Old Oct 18, 2008 | 07:50 PM
kingrich's Avatar
kingrich
I took apart the airbag and the yellow "dial" that says turn 6 times along with the other instructions, I followed. It does not click when I turn it to the right but to the left it clicks.
I have tried the turning process many times, Is it something I am doing wrong or is it the actual the middle "dial" piece that needs to be replaced?
My only guess is that when I look into the clear part of the "dial" i can see the cables somewhat tangled?
Old Oct 19, 2008 | 08:25 AM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
The middle dial piece that you are talking about is the clock spring. Its under the airbag and all. That spins and then after long use is usually looses its contacts or breaks inside then you use you cruise control. Replace the clock spring and you should get all of your functions back and you will loose the noise.
Old Oct 19, 2008 | 12:24 PM
kingrich's Avatar
kingrich
Thanks a million for all the replies. Gonna get a quote come monday or maybe someone here has one with a nice price!
simplecar
RX - 1st Gen (1999-2003)
Feb 21, 2019 08:50 PM
valkyrie03
Dec 27, 2010 08:50 PM
GSRSRT
Jan 6, 2010 11:23 AM
bigd480
May 21, 2006 08:17 AM
DJ SprinklesNJO
Dec 1, 2004 07:24 PM
