2jzge-t how much boost?
this is probably a very common question to ask and if theres threads that you guys can point me to id appreciate it, cuz i tried searching for some helpful info but came up with nothing...so here it is i need to find out what kinda boost i can run on my sc, i have a t61 turbo, 550cc injectors, tt headgasket, 255 walbro fuel pump, map ecu...im currently running 10lbs but ive been reading some stuff and i hear you can run some more...any info would help thx
not to be a ****, you didnt search hard enough....also check out clubna-t.com.
good luck with everything.
what are you using to monitor your A/F?
i don't believe u should be anywhere close to 20lbs on a tt headgasket unless u can totally control timing. i could be wrong though...
yes stock ge pistons 2.5 mm hg and 19psi gets me there but aem ems will get me alittle more with alittle less boost .. stock ecu does not like boost
