the pistons dont have to come out during a head gasket replacement, although the cams have to come out. the cams that ttc sells will set you back about a grand so it might not be in the budget.
my suggestion, is to consider putting in a lower mileage 1uz and do the basics: timing belt, water pump, and starter.
aslong as it's an early SC (pre 95 i think), you won't do any internal damage.
the car i mentioned that i had purchased, that's exactly what happened.
the t-belt had jumped. it still ran, but it ran poorly at anything more than about 2000rpm. i put the belt back where it was supposed to be, and it ran great!
as unlikely as it may be, maybe yours jumped more than 1 tooth, though that would seem unlikely with a t-belt that new. Maybe your guy forgot to pull the pin out of the tensioner, and the belt wasn't under tension.
easiest to hardest!
the smoke on the other hand, that i can't explain. What colour smoke?
is there coolant in your oil or oil in your coolant?
take it get a second opinion for all you know the valve could be stuck thus giving no compression.....but not seeing the car first had i'd say get a second opinion and if you need a head gasket just drop a motor with less miles lots cheaper and easier to do
btw there is no such thing as bullet proof on a car
What color is the smoke? Is there any oil mixed with coolant? If you remove the oil cap after letting the car sit overnight and see some white residue (coolant mixed w/oil) and have white smoke?
Has the car overheated latey? The above are signs of blown head gasket, but usally overheating is involved.
I just hate to say head gasket, so basically the car will turn over but does not fire?
Originally Posted by MERXUS
well get this my water pump, timing belt , serp belt, rad, hosing were all replaced about 5 months ago if even
my car: 164000mls (its actually in kms but i converted it for you )
dudes.. i treat my car like a baby... always, motul synthetic oil, reg manintenance.. i dunno what the heck happened...
im kind of pissed since it is supposed to be bulletproof...
guy that im dealing with is japanese mechanic --hes been working on my ride for years--i hope he is right about this...
do you guys think there could be something else wrong with my car?
it cranks but only smoke comes out and no comp...
