1992 sc400 suspension torque specs
Old Sep 9, 2008 | 12:10 PM
alanchad's Avatar
alanchad
Default 1992 sc400 suspension torque specs
I just replaced most of the suspension both front and rear, and cannot find the torque specs for the control arms, ball joints, end links, tie rod ends, steering rack bolts, shocks, etc.
I would really appreciate it if someone can point me in the right direction.
Thanks,
Alan
Old Sep 9, 2008 | 06:14 PM
TheMole's Avatar
TheMole
These specs are from a 1993 SC300:
Remember to keep in mind that ft-lb is the second number in the parentheses.
Front Suspension
Lower Control Arms, Balljoints, Endlinks
Upper Control Arms, Shocks
Rear Suspension
Old Sep 10, 2008 | 06:25 AM
alanchad's Avatar
alanchad
Default Torque specs
Thank you sir.
That got most of them.
Now I just need specs for outer tie rod ends, steering rack bolts, front stabilizer bar bracket bolts, front upper ball joint, and rear upper control arm bolts and rear upper ball joints.
The pics also show the stabilizer end links twice with two different specs(47 and 54). Maybe I am just reading it wrong?
Thanks again for the assistance.
Alan
Old Sep 10, 2008 | 09:04 PM
TheMole's Avatar
TheMole
For the front endlinks, go with the 54. I believe 47 is for the shock absorber bracket.
Old Feb 20, 2015 | 07:50 AM
megamax's Avatar
megamax
inner tie rod specs??
Hayk
34
Jul 17, 2025 06:09 AM
deadguy
Aug 3, 2019 06:00 AM
scguy
Sep 24, 2013 12:44 AM
biopeter
RX - 1st Gen (1999-2003)
Feb 12, 2011 09:37 AM
