alternator problems
Old Sep 6, 2008 | 10:08 PM
speed6's Avatar
speed6
Default alternator problems
battery light comes on at idle and low rpms
goes away at high rpms
new alternator installed.
same problem
any suggestions?
Old Sep 6, 2008 | 11:07 PM
SCjzz's Avatar
SCjzz
did u get a new battery dude?
Old Sep 6, 2008 | 11:17 PM
speed6's Avatar
speed6
uh yea and belt
Old Sep 6, 2008 | 11:46 PM
JspecSC3's Avatar
JspecSC3
Get a volt meter and test both the current on the battery and the alternator.
Old Sep 7, 2008 | 12:02 AM
speed6's Avatar
speed6
yea i got a meter at work just have to get to it (its' sunday!) so i was seeing if anyone encountered this on any make/model before, so dont call in monday cause one of my cars doenst work. my legend's wheel bearing is on the way out and i dont wanna drive that unless it's on the way to the mechanic.
and moved to the performance section? hmm i guess technically performance, i mean it's more anti performance lol
Old Sep 7, 2008 | 06:41 AM
Curry's Avatar
Curry
CL Folding 25,000
Check you're grounds, check the + wires again. For the ground that goes to the chassis, unbolt it, sand around the hole where the bolt was and then bolt it back down.
Old Sep 7, 2008 | 04:52 PM
speed6's Avatar
speed6
ok so i took off the ground and positive connaction, roloced them till you could see the brass. and still nothing. got a another alternator, swapped on a pulley off a 97, and it works, works well. SO since it was on the rack anyway, i pressure washed the underside (my friend owns a shop and i have keys so it makes it easier), changed the oil and installed a SC lip i bought at the junk yard for 2 or 3 dollars.looks better
sunday well spent!
gf not so happy
Old Sep 7, 2008 | 06:25 PM
cbrasian's Avatar
cbrasian
btw check your crank pulley as those do wear out and can lead to charging issues
gsean400
Mar 18, 2016 08:39 PM
LayedOut
Aug 16, 2015 10:55 AM
ArmyofOne
Maintenance
Nov 22, 2008 03:15 PM
Kardinal
Nov 16, 2006 09:11 AM
