GTE or GTE style
Old Aug 28, 2008 | 12:38 AM
scshinobi's Avatar
scshinobi
Default GTE or GTE style
im looking for some info on the intake manifold was wondering for the price would it be better to buy a GTE head when i boost or just the boostwerx manifold? any other alternatives to the manifold i dont want it going over the engine i want it like the GTE manifold make life a lot easier or would the GTE intake manifold bolt right up not sure but i think that it wouldnt line up from what ive researched? sorry if its a double post couldnt find much info gave up
Old Aug 28, 2008 | 07:07 AM
Biggu's Avatar
Biggu
as far as i know the GTE head is not compatible on the GE block. im pretty sure of that as if it was many more people would have it. as far as a styled like GTE you can contact mark at XS-Power, he made one for production but ive never heard from it since. if you have the money swap out the head or put say a complete 1jz or 2jz-gte engine in.
Old Aug 28, 2008 | 07:51 AM
TJohnson's Avatar
TJohnson
The GTE head will go on the GE block without issues mechanically, which is to say yes it will bolt to it but thats where the compatibility ends. The electronics is what become the issue. You can no longer use your stock ECU as the GTE head has no provisions for a distributor and just about everything is different.
The intake manifold and exhaust manifold patterns are different on the GTE as well. The GTE intake will not bolt up to the GE head. Some welding and fabrication would be required. There are a few intake manifolds out there for the GE head that are front face or GTE style.
Old Aug 28, 2008 | 04:39 PM
scshinobi's Avatar
scshinobi
any idea if a local shop is capable of taking my intake manifold and making it like the GTE so it doesnt go over the engine? i was reading on boostwerx and it said i would have to send my original runners in and i think they are asking way to much money if i have to provide my lower runners as a core
Old Aug 28, 2008 | 05:26 PM
Biggu's Avatar
Biggu
find a local car shop that offers fabrication and they should be able to do it. now it wont be cheap at all probably1500+ to get it done IMO
Old Aug 28, 2008 | 10:48 PM
cactusmole's Avatar
cactusmole
http://cgi.ebay.com/ebaymotors/NEW-T...spagenameZWDVW
This is probably your best bet....as far as cost goes and what not.
Old Aug 29, 2008 | 02:53 AM
cbrasian's Avatar
cbrasian
it can be done (gte intake manifold from gte to ge), and the head is compatable with the ge block but as far as electronics go you'd have to convert but it can be done.... just not worth your money
Old Sep 1, 2008 | 04:15 AM
scshinobi's Avatar
scshinobi
ive heard the ge style intake manifolds are more efficient because the Y splits the air evenly into all cylinders where the GTE the ones closer to the airfilter get more air then the ones behind it seems right but would that mean the GTE style manifold would wear the engine internals down unevenly? any input is appreciated thanks
Old Sep 3, 2008 | 05:18 PM
davidv433's Avatar
davidv433
just how much do you have to do to the ge to make the gte head fit becuase of coil packs ? and does the gte head flow better than the ge or the only difference is the manifold. cheapest front facing style manifold i found for the ge is 500$ i think on ebay.
Old Sep 4, 2008 | 12:09 AM
scshinobi's Avatar
scshinobi
what about ITB? never seen those on a 2jz but then again ive never looked
Old Sep 4, 2008 | 12:40 PM
LEX_MAN's Avatar
LEX_MAN
Interesting comment,but look at 240's ka24 they have the intake that is curling and going to the same side .Even though the 93's have the butterfly's the 96's dont ,so butterflys cant be the answer.
JDMSoarer5
Aug 23, 2012 09:30 AM
Turbo?
Feb 6, 2011 05:40 PM
evileagle
Sep 5, 2007 05:01 PM
IIJZSC300
Jun 7, 2005 05:00 PM
qtb33
Sep 8, 2004 08:53 AM
