Power steering bypass....
Old Aug 3, 2008 | 01:30 AM
forcefed86's Avatar
forcefed86
Default Power steering bypass....
Trying to bypass my power steering. I believe the bearings in it may be bad. (excessive ENG noise) It's either the ac clutch or the PS.
Just wondering if I can buy a smaller belt and bypass the PS pump? Is there a way of doing this?
Thanks
Old Aug 3, 2008 | 08:42 AM
OneJay's Avatar
OneJay
I would just fix the power steering.
Old Aug 4, 2008 | 07:58 AM
blacice83's Avatar
blacice83
i have the dame problem! PS pump went out and now i have a nosie coming from the right side of my engine. But to make a long story short im just going to fix the pump. Driving with no PS with 20in wheels is a workout i dont need,lol.
Old Aug 5, 2008 | 12:10 PM
Gunnar's Avatar
Gunnar
On fbodies you can just run a shorter belt and bypass the pump altogether, I'm not sure how well it'd work on a 2JZ with the tensioner placement but by all means look into it.
If you really decided to bypass it for good, a trick to ease the steering up a tiny bit over just not running the pump is to run the lines from the rack back into each other so the fluid just runs through the rack instead of up through a non moving pump and back down.
Old Nov 28, 2008 | 03:11 PM
lexxxuspr's Avatar
lexxxuspr
So has anyone bypassed the ps ever on a 2jz?
BrittonJ85
Apr 28, 2010 10:39 AM
lsflame
Nov 21, 2006 05:59 AM
khepera
Jan 22, 2006 11:39 PM
92es300v6
Aug 10, 2005 06:03 PM
kmn5
Maintenance
Jan 16, 2004 05:24 AM
