Drivers side window switches stop'd working
Old Jul 24, 2008 | 11:20 PM
ehannigan's Avatar
ehannigan
Default Drivers side window switches stop'd working
Ok, so of course this happens when the window is down...driver's side switches will not raise driver window or lower/raise passenger window, however...
mirror adjustment works
window lock works
door lock works
and passenger side switch works fine (in passenger door). Don't think it's a fuse - shared with both doors? Master switch bad?
Any advice?
Thanks !
Old Jul 24, 2008 | 11:26 PM
unreal-'s Avatar
unreal-
CL Folding 10,000
MAster switch is bad.
I had the same on my passenger side window switch. It wouldn't lower the window, but it could raise it, but on the driver side, it could do both. Sometimes the contacts could be dirty, or the switch could have went bad.
If you are up for it, take it apart and clean the contacts. If not, just buy a new switch from aliga for ~60.
Old Jul 24, 2008 | 11:43 PM
ehannigan's Avatar
ehannigan
Ok, so is there a writeup anywhere on how to clean the contacts in the archives by chance? I bet I could do it with some guidance but just in case...
Who is aliga?
Thanks !
Old Jul 24, 2008 | 11:52 PM
Hil's Avatar
Hil
That happened to me.. turns out the wires were bad. Someone fixed it for me though
Old Jul 25, 2008 | 03:18 AM
cbrasian's Avatar
cbrasian
its cake walk to do just time consuming chances are the switch is bad and best way to check that is to check that power is going to the switch
if so then it confirms from the switch to the window regulator
Old Jul 25, 2008 | 10:00 PM
unreal-'s Avatar
unreal-
CL Folding 10,000
Who is aliga?
Thanks !
I dont think there is a writeup for cleaning the contacts. I would bet its pretty self explanatory: take the switch out of the door, disconnect any wires behind it, and find a way to take apart the switch assembly.
aliga is a guy that frequenty sells used SC parts from junkyards, etc.
https://www.clublexus.com/forums/sc400-300-classifieds-36/ (Classifieds forum, check any thread started by him)
KiNGD206
Jan 10, 2014 07:13 PM
misterlv
Jun 9, 2012 12:42 PM
g4ebguy90
May 5, 2012 03:03 PM
SolTrain99
Jan 4, 2010 04:04 PM
Luv Da Lex
Oct 10, 2008 12:35 PM
